Results 1 to 10 of 10
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Apr Ecu Question
    Quick questions for you gents/ladies.
    Is my 2-program APR ECU suppose to be "applied" as soon as I start my engine without me utilizing the flipswitch to turn it on?
    Reason I'm asking is because when I start my car and don't bother switching the ECU programming on, I still push out ~15 to 18PSI.
    Other questions that I'm wondering about is what exactly does a chipped ECU affect and how does it push the stock boost from 8 to 15?
    2015 B8 SQ5
    Click Here
    Past
    Oct 25 2006
    '98.5 A4 1.8tqm Sport, '01 MDX
    Oxford, CT
    Re: Apr Ecu Question
    Have you tried switching it to stock mode and then shutting it off? How does it start then? In my A4 with APR - It holds the last mode you had selected.
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by ct1.8t4me View Post
    No I have not.
    I'm still trying to figure out where my "stock" mode is. I think I've deduced that program 1 may be 93-mode, and program 2 is stock.
    So the ECU doesn't restart itself after engine shut-off?
    2015 B8 SQ5
    Click Here
    Past
    Senior Member Three Rings lowered97a4's Avatar
    Mar 08 2007
    08 turbo busa 09 nissan Gtr
    ct
    single flashing is stock then it starts flashing twice thats 93, they do 3 flashs i think on each program
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    JHM/AMC trans rebuild
    03 Rs6
    Wagner intercoolers carbon fiber shrouds
    Ecu/Tcu tune
    Cats Removed
    Mar 08 2007
    ct
    Press and hold the "set" button on your cruise control. After approximately five seconds, the "check engine" light on your dash will begin to blink once per second. This will tell you that you are activating program one. This blinking sequence will continue for approximately five seconds.
    After this five second interval, the "check engine" light will begin blinking twice per second. This will indicate that you have activated the second program. This process is continued to access any remaining programs you may have purchased. (three blinks = program three, four blinks = program four).
    Step 2: Once you have activated the desired program, simply release the "set" button. The "check engine" light will go off, and you will be locked in that program until you change it.
    got these of there web page for you maybe it will help
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    03 Rs6
    Ecu/Tcu tune
    Cats Removed
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    its supposed to hold the previous program so maybe you have a boost leak
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by lowered97a4 View Post
    I already know how to initiate the program, I just didn't know what the layout of the programming is...is it:
    1. 93 octane, 2. stock
    or
    1. stock, 2. 93 octane.
    Once I figure out which layout it is, I can than figure out how to turn off the program. As of right now, I'm running in 93 program and didn't know if the ECU resets itself after I shut off the engine.
    2015 B8 SQ5
    Click Here
    Past
    Apr 13 2008
    Tennessee
    or
    if you have the programmer, it could be either of those
    APR *usually* puts stock mode first, but if someone has a programmer, they could load them differently
    Apr 13 2008
    Tennessee
    oh, and it doesn't reset itself; it remains in the last selected program
    Dec 02 2007
    DC/MD/(VA)
    I think I've figured it out.
    Park
    Let car run between 45secs to 2 minutes (depending on how hard you pushed your turbos)
    Turn off engine
    Turn to ON position
    Set to Program 1 again...
    Took me a few experimental runs and numerous turning on of the engines to figure it out.
    2015 B8 SQ5
    Click Here
    Past
