Results 1 to 22 of 22
    Veteran Member Four Rings Redgoat's Avatar
    Sep 16 2005
    How would you know if your MAP sensor went out?
    Anyone....??
    -Karl
    NWQuattro - Northwest Audi Club
    USP CLUB MEMBER #8
    BetaAlphaTau member #10
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Re: How would you know if your MAP sensor went out?
    If I understand correctly, log measuring block 115 with your VAG COM (you do have a VAG, don't you??) to see if you're not meeting actual vs. requested boost. If things are looking fishy then you could have a MAP sensor out.
    I'm sure an OG will chime in to confirm or refute. But that's a good starting place.
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    Quote Originally Posted by Redgoat View Post
    Anyone....??
    You mean the MAF sensor as in the outlet of the air box?
    Well you would have a "Check Engine Light" and the car would run rough. You could unplug it and it might run better but in a back up mode.
    If you have a Vag Com you could log block 002 and read the Mass Airflow Sensor in G/S (grams per second).
    If you don't get a read out chances are the MAF is blown.
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Could anyone confirm Maf readings at idle? Normal vs bad/dead Maf
    Beta Alpha Tau member #56
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by FourRings80 View Post
    IIRC about 2 t 3 G/S at idle.
    Jun 30 2007
    Raleigh, NC
    no he means the sensor that's located on the top of the stock SMIC - commonly known around here as a MAP (manifold absolute pressure) sensor even though i guess technically that's not what it is.
    and i have no idea how to tell if one is bad or not... i guess do what we do with everything else. unplug it and plug the hole it came from -- drive the car -- if it gets worse, the sensor is good.. if it stays the same it might be bad
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by B6Lovin View Post
    Yeah that's why I was asking because I wasn't sure.
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    might help, (CO AVANT and diagnosticator parts)
    http://www.audizine.com/forum/showth...ght=Map+sensor
    REVO/EUROCODE TUNED
    Deutsch Teile Haus
    Sep 16 2005
    I was referring to the MAP sensor.. the reason I ask is that I got the codes
    Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
    P0234 - 001 - Upper Limit Exceeded
    Manifold Pressure/Boost sensor (G31): Signal too High
    P0238 - 001 - Upper Limit Exceeded
    and one other that I cant remember off the top of my head..
    The car started acting a little funny ie give it a little throttle and Rev's go way up and keep going till you shut it off. I had just finished installing the water/meth and thought ohh well maybe it needs a TBA, The test drive was litterally a slow 15mph drive out of the shop and around the block.. coming around the 3rd corner somebody backed out and hit me.. So i ended up with some right rear quarter panel damage and wheel rubbing.
    Couldnt continue to test the car out.
    Car drove back home just fine at low speeds with slight rubbing. Had the car towed to the Body shop, and they called me two days later saying that they gave the car a little gas and the revs went way up.. the next day the battery was dead so they charged it ... then the car wouldnt start.
    -Karl
    USP CLUB MEMBER #8
    Sep 16 2005
    Bump
    -Karl
    USP CLUB MEMBER #8
    Sep 13 2007
    04 Atlas Grey A4 1.8TQ Avant
    Quebec, Canada
    Just thoughts here, I'm very far from the knowledge of people like diagnosticator
    Did you change your N75 for the race version ? Do you have a manual boost controller ? Maybe your DV is blocked closed ?
    FXK03 - Stasis SS Coilovers - Forge DV - Forge TIP
    Sep 16 2005
    I have a forge bov, and an EBC
    -Karl
    USP CLUB MEMBER #8
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Time to pull out the good 'ol voltometer. Need to test all the wires at the sensor plug to the ecu for continuity (ohm). I thought it was a bad sensor on mine but found out that the wire INSIDE the wire coating separated by ~1". Never have I seen a wire separate like that 2-3" back from the sensor plug while still being inside the wire coating. Wierd shit. I might have an extra sensor lying around too if you need to try it. They are expensive.
    Sep 16 2005
    Would this cause the car to not start? Or am i looking at possible something else?
    A friend works at the dealership so I can get the part at cost basically.. or I can go through worldpac
    Havent checked cost/list though.. any idea on what that is?
    -Karl
    USP CLUB MEMBER #8
    Feb 12 2004
    Everywhere
    I think $80 or something like that. It caused my car to run like shit.
    Sep 16 2005
    Hopefully its just this and the fact that it needs a TBA
    -Karl
    USP CLUB MEMBER #8
    Sep 16 2005
    Does anyone know the part number for the sensor?
    -Karl
    USP CLUB MEMBER #8
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I can pull mine off and check tonight if you want.
    -Doug
    Sep 16 2005
    I would greatly appreciate it!!
    -Karl
    USP CLUB MEMBER #8
    Sep 16 2005
    Bump.. anyone have the part number.. dealer has no clue what im referring to.. ughh
    -Karl
    USP CLUB MEMBER #8
    Feb 12 2004
    Everywhere
    Sorry no go on my extra map sensor... the node is broken that goes into the piping.
    Part #:
    0 261 230 073
    038 906 051 D
    Sep 16 2005
    Sweeet Thank you sir!!
    -Karl
    USP CLUB MEMBER #8
