Results 1 to 11 of 11
Thread: bumpstops.
    May 21 2007
    Florida
    bumpstops.
    i just finished my h&r sport/bilstien sport install today and i noticed i am getting a thumping/rattle type noise and a relatively rough ride. i was told by someone i may need to cut my bumpstops. which im pretty sure they are correct because i checked the bolts and everything is tight. im just wondering if i should cut the top or the bottem off? does it matter? how much should i cut off? do i even need to keep them on? thanks guys!
    2018 Navarro Blue Q5
    Senior Member Three Rings Grenade's Avatar
    Aug 10 2005
    04 USP
    Las Vegas
    Re: bumpstops.
    Is it only when you go over bumps in the road? If so, you may be taking the front's back off. What happens when you install the spring onto the strut, is that the spring keep tension on the rod, that holds the top nut on, and it does not fully seat, causing alittle bit of play/area when the suspension is fully loaded. When you installed the springs, how many threads were showing on the top of the nut? There should have been 3-5 threads showing, the more the better. If you did not use an impact wrench you may have a problem all so. HTH
    USP CLUB MEMBER #686
    May 21 2007
    Florida
    Re: bumpstops.
    i used an impact wrench. there were at least 5 threads showing on each. i actually took them back off today after finishing the rear to double check what youre talking about. im going to cut the bumpstops and go from there...can anyone answer my questions please?
    Aug 10 2005
    04 USP
    Las Vegas
    Re: bumpstops.
    Hrmm, well I dont know then. I am having a similar problem, but only on passanger side, and I dont have a harsh ride, but I beleive its the sway bar end. The bolt was messed up, so Its not 100% against the endlink.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: bumpstops.
    Is that a high sqeezy noise??? I got the same problem. And i also feel the front struts sometimes when i go over a speed bump.
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    May 21 2007
    Florida
    Re: bumpstops.
    ^no its not. its a 'thud' type noise. i get the high squeeky noise too. im pretty sure thats just worn out bushings or something.
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: bumpstops.
    Could you describe that thud sound plz?
    when u go over the high but small in size speed bump, do u feel your struts kind of? When your wheels touch the ground?
    Veteran Member Four Rings JBM's Avatar
    NorFOLK, VA
    Re: bumpstops.
    question-did you load the suspension before bolting everything down?
    "Give a Man a Fish, Feed Him For a Day. Teach a Man to Fish, Feed Him For a Lifetime"
    '02 B6 1.8T, UnitedMotorsport Tuned FrankTurbo L21, 550CC, 3" MAF, BB Intercooler, 007, 034 HFC, Neuspeed Exhaust, B5 S4 Brakes, KW Suspension, S4 Recaro, and the list goes on.
    Aug 10 2005
    04 USP
    Las Vegas
    Re: bumpstops.
    Quote Originally Posted by JBM View Post
    I know that everyone say's to do this, but how the hell do you do this? I mean its easy to do the lower shock/strut bolt is easy, but uppercontrol arms, and top strut bolt?
    NorFOLK, VA
    Re: bumpstops.
    What that thud is probably the top strut bolt, but after you took the car off the jack did you tighten the top three bolts for the strut mount.
    May 21 2007
    Florida
    Re: bumpstops.
    ^what he said. i tightened everything up and put the wheel on, lowered it down and tightened the top 3 bolts again. not much, but a bit.
