Results 1 to 3 of 3
    Registered Member Two Rings
    Feb 21 2008
    Rahway, New Jersey
    will a set of stock s4 headlights fit in my car?
    I have a 96 a4 2.8 and I know that i obviously have to trim around the upper fenders to get the one piece headlights to fit, but as far as being plug and play is it? Do i need to buy any different wiring harnesses or anything?
    Thanks guys.
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    Re: will a set of stock s4 headlights fit in my car?
    yes it will work. you will need to take the wiring harness out of your old headlights and put them into the new onces. or i believe ECS sells a convesion kit for like 50 bucks. i just swapped the harnesses to save a few bucks and works fine.
    heres the DIY i used
    http://www.audiworld.com/tech/elec88.shtml
    and yes you also need the trim the fenders
    2004 Subaru Impreza WRX
    Aspen White
    Dec 05 2007
    You will have to trim around the fender for the headlights to fit. There is no way of stepping around it. But there are many people whom have done that upgrade. The sawzill seems to be people's best freinds in that situation. I don't know about the harness, but I just placed the Valeo Ecode headlights in mine specified for the A4 and S4. But the harness for the turn signals were different. I ended up having to dremel a peice off the stock turn signal holder and using that on my new headlights.
    In case you are interested
