Results 1 to 14 of 14
Thread: help!! with TCM
    May 04 2008
    tucson
    Unhappy help!! with TCM
    well i guess i need to replace the transmission control module based on what the stealership told me but the fu((*&ing tcm is $1300 i got a tiptronic 2004 1.8t please help me to find a cheaper one thanks!!!
    Veteran Member Three Rings RED1.8T's Avatar
    Jan 19 2007
    Columbus, Oh
    Re: help!! with TCM
    I would start with getting the part # and then looking around
    May 04 2008
    tucson
    Re: help!! with TCM
    ok can someone help me with the part # T_T or where can i get it
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    Re: help!! with TCM
    www.car-part.com ? is the tcu married? get a used one and stuff it in and do the vag-com re-train on the shifter. might ask around to see if the tcu needs to be coded to the ecu as that might require a dealer to handle without the SKU (if its necessary).
    what killed it? water?
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    May 04 2008
    tucson
    Re: help!! with TCM
    i don'tt really know what killed it thanks for the info man, and what do you mean by married..?
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    Re: help!! with TCM
    i just looked on all-data and it says the part costs $1324.88 part # 01J927156FF Trans Controller A4, Cabriolet A4
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Aug 26 2005
    Re: help!! with TCM
    Quote Originally Posted by kakashisan View Post
    The part number is 8E0 927 156 AA, There are a couple on eBay priced a lot higher than you should pay. If you google that PN, often a seller's website is found, I recently bought a B6 TCU for $199. The TCU does not need to be coded or married to the ECU no SKC is required, just install and go. What is the specific reason the dealership says the TCU must be replaced?, that is, what exactly is the problem that is supposed to be fixed by replacing the TCU?
    May 04 2008
    tucson
    Re: help!! with TCM
    welll thanks guys for all the info welll i got the flashing gears thing
    The tiptronic doesn work so they run a diagnosis and thats what i need it to replace
    Aug 26 2005
    Re: help!! with TCM
    I guess I should have asked first, is you trans the 5HP19FLA or the CVT?
    In either case the tiptronic function error and the back lighted shift display can be caused by a problem in the shifter and depending on the DTC codes, may not have anything to do with the TCU. In the case of the shifter HAL sensor issue, replacing the TCU won't fix the shifter problem. What are the DTC numbers that are stored specifically?
    May 04 2008
    tucson
    Re: help!! with TCM
    I know that it has six gears when was working and the code that it was coming out is that there was a communication error with the transmission control unit, and sorry to make this harder but my mom toss out the codes since she didnt know what was for can i get the codes from autozone? Also i already took it to three mechanic shops including the dealer and the three of them gave me the same answer
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Re: help!! with TCM
    6 speeds would make it the CVT.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    May 04 2008
    tucson
    Re: help!! with TCM
    there you go thanks
    Registered Member Two Rings SouthflA4's Avatar
    South florida
    Re: help!! with TCM
    My TCM went bad....but it was only throwing a CEL and nothing else was wrong mechinaclly with the car. Thank GOD for warranty....I was still under for about 6,000 more miles when it went bad.
    May 04 2008
    tucson
    Re: help!! with TCM
    wow man you're lucky i will just keep looking on google see if i can find one somewhere because i'm not going to pay $1324 for a new one does anybody know what can happened if i don't replaced it will it just be stuck in limp mode ?
