Results 1 to 17 of 17
    Senior Member Three Rings tarunpatel's Avatar
    Jul 11 2008
    Surrey, B.C.
    Any B7 A4 on 19'' Staggered Rims!~ new on this site need help~
    Hey there you guys i'm new to this site and wanted to get help from you guys! Wanted to know how many A4's have 19' Staggered Rims on there ride also what type i'm thinking bout getting the Axis Penta 19x8.5 front and 19x9.5 rear. I have not been able to find pics of the any B7's with staggered setup please post pics and help me out thanks~
    Veteran Member Three Rings cyanidecologne's Avatar
    Oct 26 2006
    2006 BMW X5 4.4i Sport Package, 2006 Audi A4 2.0T Quattro
    Tustin Ranch, Ca
    Re: Any B7 A4 on 19'' Staggered Rims!~ new on this site need help~
    Jul 11 2008
    Surrey, B.C.
    Those are nice anyone else with rims that are staggered!~
    Registered Member Three Rings SGVA4's Avatar
    Mar 03 2008
    07 3.2 Quat SLine, 08 MKV SE
    626 SoCal
    I run staggered works euroline fs on my b7. you might need spacers to clear Axis Pentas
    Work Euroline FS/Falken/Cupra R/HID yellow fogs/H&R/Eibach/Bilstein/Apexi/Optic Black RS4 Grill
    Hoen plate bulbs/ZiZa city lights/RS4 foglight grill coming soon!!!
    "J Spec B7"
    Senior Member Three Rings tivs31's Avatar
    Feb 07 2008
    Lemont IL
    I'm running work ls's 19x8.5 and 19x9.5
    Veteran Member Four Rings TinaTbolt's Avatar
    Sep 17 2007
    2012 C7 A7 & 2015 Q5 TDI
    San Diego
    ive got DPE S20s that are 19x8 and 19x10
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    I'm running RH-RAN Crosslines 19x8.5 and 19x9.5
    Jul 11 2008
    Surrey, B.C.
    So do any of you guys have issues with rubbing i'm lowering my car next week with the Neuspeed springs!~
    Feb 07 2008
    Lemont IL
    I do occasionally but not unless I go over a pretty big bump. Depending on the wheels an 8.5 and 9.5 will fit in the fenders pretty easily. You need to ensure you have the right offsets to aviod rubbing.
    Mainly about a 36-37 up front and 40ish in the rear.
    With the suspension, depending on how low you go will determine how much you rub as well. Also depending on the size of sidewall of your tire will matter on how much you rub too. I am running a narrow 215/35/19 and a 235/35/19, which is pretty streched, but i am also running pretty low compared to most. the narrow tires alow me to run without rubbing.
    Simply saying yes I rub, or no I don't isn't quite the best way to determine if you will rub or not
    Mar 03 2008
    626 SoCal
    Quote Originally Posted by tivs31 View Post
    tivs,
    whats your offset? and did you need spacers to clear your works?
    damn dude, your running some stretched ass tires!!
    to the op im running 30et and 40et front and rear and 235/45/19 and 245/35/19. will only rub if i got rear passengers so i dont usually drive if going out in groups lol
    im dropped on eibach pro/bilstein
    "J Spec B7"
    Mar 03 2008
    626 SoCal
    Quote Originally Posted by tarunpatel View Post
    nuespeed race or sport?
    "J Spec B7"
    Jul 11 2008
    Surrey, B.C.
    Quote Originally Posted by SGVA4 View Post
    I'm going with sport!~
    Feb 12 2004
    PA-NJ
    With sport I doubt you'll rub. I have H&R coilovers and they are set fairly low.
    I only rub a tiny bit on the rear when I go over a big dip in the road...and only when I have passengers.
    Feb 07 2008
    Lemont IL
    tivs,
    I'm running a 40 on an 8.5 up front, and a 38 on a 9.5 in the rear. I didn't need a spacer until I just recentley changed my pads this weekend....
    Now i'll be running a 5mil up front to clear the brakes it'll also look more balanced, the fronts were tukin to much for me.
    I'm not 1000 percent on the exact specs cause I ordered them like 4 months ago
    Veteran Member Four Rings 10MPG's Avatar
    Oct 25 2006
    Current:
    Bay Area CA
    Boring day at work so I'm making my contribution to the thread instead.
    19x8 front/19x10 rear, no idea what the offset is but the front offset clears BBK:
    Jul 11 2008
    Surrey, B.C.
    Hey man you got more pics of the rims looks sooo good!~
    Jan 06 2008
    Dacia Sandero
    Arizona
    Quote Originally Posted by tinaalia View Post
    Your car is super clean! I like it a lot!
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
