Results 1 to 4 of 4
    Awaiting Confirmation Two Rings
    May 24 2008
    2003 Audi A4 3.0 Quattro, 2008
    Semi-lovely Bradford, Vermont
    Angry Help with drivers window?
    My drivers window won't work. All others will, but only from the drivers control switches (not from the individual door switches). When I hook up my VAG-COM, it tells me that it can't communicate with the window controllers. So my questions are: Is this a Short Circuit? A bad drivers window controller? Or, maybe a bad Comfort System Controller? (I've changed the switches, didn't help). Any and all advice/opinions would be appreciated. Thanks, Dean
    May 24 2008
    Re: Help with drivers window?
    Bump! Anyone?? Anything??
    May 24 2008
    THANKS!
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    sounds like its the control module if vag-com cant communicate with them
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
