Results 1 to 9 of 9
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Can't get primary pass. 02 out.
    I went to Autozone to get a 18 1/2" breaker bar and 02 socket. took off my acc. hose and top of airbox/MAF. I couldn't even torque it enough to budge the sensor.
    does anyone have any strategies to get it out? maybe a little WD40 or PB blaster to loosten it up?
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Re: Can't get primary pass. 02 out.
    Im in a similiar boat but I have to replace my front driver side O2 out.
    Just a suggestion, couldn't you take out your entire AIRBOX out to get a little more room to budge it out?
    I know the entire airbox is pretty easy to take out
    2015 B8 SQ5
    Click Here
    Past
    Jul 07 2007
    Tempe, AZ
    taking out the bottom half doesnt give any more room. I can take that shit out in my sleep too.
    Senior Member Three Rings eliTTe's Avatar
    Arlington, VA
    soak it in pb blaster for as long as you can, then try it. that always works for me
    Then: 1985 Audi coupe GT, 1990 Audi 90 sport, 2000 Audi S4 stage 2+, 2002 Audi TT 225.
    Now: 2011 Audi S4
    Senior Member Two Rings Jayco88's Avatar
    Jun 02 2008
    2000 S4
    PB blaster ftw
    -It's got nothing to do with your vorsprung durch technic, you now.-
    md
    the pass side 02 is the easier side.. you dont have to remove the air box, the pass side should only take you about 30 mins with the right tools.. the drivers side is another story !! g/l
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    For me I did 2 different audi's one was a A6 2.7, then did my S4 and both didnt really have problems getting the o2's to come out.
    i wonder if you tried a different 02 socket - if that would help?
    I borrowed one from a friend who had snapon tools.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Apr 05 2007
    try using a crows foot wrench instead of the o2 socket. should allow you to line up a little better and not have the wires get in the way at all.
    also, if you are using 3/8" socket tools maybe try upgrading to 1/2" for a bit more heft/torque.
    Feb 01 2008
    Missouri
    OMG don't even get me started!!! I coated that thing with PB blaster and pulled on it for hours. I ended up removing the entire airbox, MAF. Y-pipe. and still had NO luck at all... I talked to a local shop and they said that most of the time they end up cutting the wire and other bits off then using a air-power gun to get it off!
