Results 1 to 40 of 45
    Feb 15 2007
    marimont
    complete part out (now with pictures)
    Engine:
    1.8t engine with 9.0:1 JE pistons, scatt rods, race ware headstuds, AEB head w/ o/s valves: 3500
    atp fuel rail : 90
    bahn brenner fpr housing: 75
    tylor sport adj fpr: 120
    seimens 850cc injectors: 250
    AEB I/M: 85
    034efi IIC w/ tunning and harness: 1750
    034efi equal length: 800
    gt35/40 turbo: 800
    synapse bov: 200
    FMIC setup w/ adel wiggins clams: 1300
    full 3" exhaust w/ magnalow muffler: 700
    greddy profec b spec II: 200
    SSP electric fan kit: 100
    Black housing headlights: 85
    Oil catch can setup: 250
    Tial wastegate w/10 psi spring and 14.7psi: 200
    DBC pedal: 100
    Throttle cable: 35
    Throttle cable bracket: 35
    Ross maching velocity stacks, D plenum, AEB runners, Alum plate: 300
    transmission w/southbend stage 5: 800
    suspension:
    agency power front sway bar endlinks: 100
    rear neuspeed sway: 200
    034 engine and tranny mounts(stiffest ones): 200
    koni coils: 650
    roja d2 17x7 : 500
    Audi TT cariers: 150
    A8 drilled rotors: 100
    ss brake lines: 65
    exterior:
    vis hood w/aero catch latches: 300
    fiber images c/f trunk: 600
    Interior:
    grant wheel setup: 150
    innovate wideband: 200
    digital tachometer: 75
    corbeau FX1 pro seat with bracket and schroth belt: 500
    I probally have more I'm leaving out. So just ask for it. Also will sell the rolling chassis.
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Re: complete part out
    Pm sent regarding:
    ss brake lines: 65
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    ill take the profec b, pm sent
    ::2002 S6
    Oct 22 2006
    Wat color is interior and are u letting the armrest go?
    Feb 15 2007
    marimont
    Interior is grey but, I don't have that item. Sorry.
    Q7, Q7, F-type manual
    random, but headlight washer nozzle?
    Feb 15 2007
    marimont
    Nozzle or caps? I have both nozzles and lines. Only one cap though.
    Senior Member Two Rings deux321's Avatar
    Oct 21 2004
    2001 a4 1.8tqms
    central cali
    how much for ABS module!?
    Feb 15 2007
    marimont
    I'm probally keeping that for my Avant.
    Jun 30 2007
    Raleigh, NC
    did that other guy buy the profec b? if not i'll take it. PM sent
    and what flange is the turbo? .....jw.........
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Feb 15 2007
    marimont
    It is a t3 flanged turbo. Also have all the lines for it
    Active Member Three Rings panix73's Avatar
    Mar 17 2006
    Battleship Kruzer
    Long Island, NY
    ygpm'd
    Innovate.
    Dec 13 2007
    05 Denali, 64 baja bug, 67 beetle, 04 passat W8.
    Eastern CT
    have any pics of the sway bar end links? or a link to the web site?
    Veteran Member Three Rings prodrive's Avatar
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    How many miles on the 034 engine mounts ? 2 engine and 2 tranny right ?
    Just A4 ... A4 which we know
    2.0L - HTA35 - Cat3658 -Autronic EMS - Autronic 500R CDI etc..
    Feedback: Clicky
    Feb 15 2007
    marimont
    The agency powers use a spherical bearing for complete rotation. They are ment to be used on the rears of a subi but fit the A4 in the fronts.
    There is probally on a few thousand miles on the mounts. This car was mainly a garage queen.
    PMs responded to.
    Feb 15 2007
    marimont
    bump
    Feb 15 2007
    marimont
    bump
    Feb 15 2007
    marimont
    Jan 30 2007
    CLS63 AMG
    Bottom of the mountain
    Bit of a strange request but do you have the oil sensor which is in the bottom of the sump?
    Feb 15 2007
    marimont
    yes
    Feb 15 2007
    marimont
    bump
    Veteran Member Three Rings LDetter's Avatar
    Mar 10 2008
    York, Pa
    Pics of the headlights?
    Feb 15 2007
    marimont
    I'll get some later today.
    Driver side washer cap- sold
    TT carries- sold
    Oil drain and feed-sold
    Feb 15 2007
    marimont
    Feb 17 2004
    Montreal
    are you selling the rear tail lights ???
    Mar 10 2008
    York, Pa
    PM sent.
    Aug 24 2005
    1999.5 AUDI A4/T/Q/M
    Chicago, IL
    Would you do the 034 engine mounts for 80$ shipped? Also, how many miles are on them?
    -Spiel
    d j s p i e l ***a t *** g m a i l d o t c o m
    Feb 15 2007
    marimont
    no I won't sell my mounts for that much nor will I split them up.
    Yes I will sell my tails. Make me an offer.
    Pms replied
    Feb 15 2007
    marimont
    Headlights sold.
    Mar 24 2006
    pottstown, PA
    pics of exhaust?
    GT35r, Cat 3653's, 034 manifold, 1000cc injectors, Ctapp tune, 44mm tial wg, 2.0 block with scat rods and JE pistons, stage 3 SPEC S4 clutch with 240 mm SPEC flywheel, full 3" exhaust, coolingmist water meth, etc.
    Oct 08 2007
    Wa
    do you still have the end links?
    Feb 15 2007
    marimont
    yes
    Feb 15 2007
    marimont
    The exhaust isn't off yet. When it is I will have pictures. Just looks like a turbo back with a magnaflow muffler.
    Feb 15 2007
    marimont
    edited
    Registered Member Two Rings
    Jun 19 2008
    florida
    do you still have the vis cf hood? and if so which one by vis is it? thanks
    01 a4 1.8tqm, apr tip, custom intake, labree hfc, custom 3" back, apr chip, greddy oil ic, eibach pro street coilovers, GodSpeed FMIC, gauges to monitor, and a loud stereo so i dont hear any squeaks or problems plus weight to help handling lol
    Feb 15 2007
    marimont
    Yes I have it. It is the oem style hood
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    just curious on what forms of payment you take if you dont take paypal? thanks
    ::2002 S6
    Feb 15 2007
    marimont
    money order/check like the others have sent
    Senior Member Three Rings gaspeedracer's Avatar
    Jun 02 2007
    2001 Imola Yellow S4
    Daytona Beach, FL/Conyers, GA
    i just recieved the first item i ordered from solowb5 today. it was shipped fast and it was in excelent condition. I'm expecting the second item by wednesday.
    "A true leader has the confidence to stand alone, the courage to make tough decisions, and the compassion to listen to the needs of others. He does not set out to be a leader, but becomes one by the equality of his actions and the integrity of his intent."
    -Douglas McArthur
    Semper Fi!!!
    Oct 08 2007
    Wa
    how many miles on the end lnks?
