Results 1 to 11 of 11
    May 21 2007
    Florida
    frozen rear camber bolt.-need fast help
    any tips on getting this bastard out? ive tryed heat, hammer, and impact gun and nothing is working. do i absolutely HAVE to take this out to get the spring out??? if not, how else can i do it? thanks.
    2018 Navarro Blue Q5
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Re: frozen rear camber bolt.-need fast help
    Are you trying to adjust the camber or take the bolt out?
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    May 21 2007
    Florida
    get it out. im installing H&Rs and bilstiens. the messed up thing is that i can get the nut off one side, but the bolt wont slide out. it spins in both directions, but loosening it up it will get stuck at a certain point and not budge anymore. i dont get it at all.
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Why do you need to take that bolt out? To install the suspension you do not need to mess with that bolt. Unless you are adjusting camber, I advise you to leave that bolt alone.
    May 21 2007
    Florida
    a4 mods says to take it out, i did on the other side and it worked like a charm. i cant get the spring out. ive gotten it pryed half out but it wont go any farther.
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    It is much easier to install the springs with the camber bolt taken out.
    I have a couple suggestions for you:
    1. Try jacking up the hub to take the tension of the spring off of the bolt.
    2. Put the impact gun on it, get it spinning, and tap the other side of the bolt with a hammer.
    Let me know how it works!
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Senior Member Three Rings Grenade's Avatar
    Aug 10 2005
    04 USP
    Las Vegas
    DONT DO THAT!!!
    Go look at the FAQ on here. http://www.audizine.com/forum/showthread.php?t=189109 Look at his las post, about taking the subframe off, side by side to do it. I did this, and its ALOT easier. HTH, take care
    USP CLUB MEMBER #686
    Veteran Member Four Rings JBM's Avatar
    NorFOLK, VA
    yeah now need to do that. drop the subframe
    "Give a Man a Fish, Feed Him For a Day. Teach a Man to Fish, Feed Him For a Lifetime"
    '02 B6 1.8T, UnitedMotorsport Tuned FrankTurbo L21, 550CC, 3" MAF, BB Intercooler, 007, 034 HFC, Neuspeed Exhaust, B5 S4 Brakes, KW Suspension, S4 Recaro, and the list goes on.
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    I did both and it made the install really simple springs slide right out, no prying necessary and its not hard to line your camber back up once you put it back together.
    2002 Audi A4 1.8TQM
    Bailey's DV
    Buy my photos here.
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    i snapped that bolt... DO NOT overtighten when putting back.. trust me... it snaps quite easily (not THAT easily, but still). its a $15 part...
    taking out: let the hub's weight hold it down for you, and you need a wrench to counter the spinning motion.
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    May 21 2007
    Florida
    i did drop the subframe. i had already done everything you guys were saying, i managed to get it out by putting a spring compressor on and having my friend bounce on it. i used a tow strap/pry bar to pull/pry the bastard out. i was amazed that this actually worked. lol...and you know, im not entirley sure i tightened my subframe back up...maybe i should check on that.
