Results 1 to 10 of 10
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    Weird sound.. anyone have a suggestion?
    when I go over bumps in my car i hear a sound in the left front wheel. it sounds like someone jingling change in their hand once. only happens at faster speeds. any one know what it could be?
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Senior Member Three Rings NVR STSFD's Avatar
    Oct 10 2007
    2003 CVT, Lexus RX 300
    Norcal
    Re: Weird sound.. anyone have a suggestion?
    I kind of get that same sound when driving next to a center divider with the window down, going anywhere from 20-40mph. Hopefully someone can give some input.
    ''Oderint dum metuant''
    Deactivated Three Rings
    Apr 11 2008
    Quick squeaks? I get them in both my fronts pretty much at any speeds.. from what I've read in other forums, its the caliper clips that cause this squeak. Others have reported it too and said it went away as soon as they had brake upgrades done.. now for a change sound? I dunno.. is it really loose coinage? lol
    Dec 06 2007
    does it sound like a faint rattle?? if so mine do it as well, it is the Brake dust covers or springs for the brakes that do that u gotta tighten it!
    -Kirk
    BetaAlphaTau Member #58
    Senior Member Three Rings Grenade's Avatar
    Aug 10 2005
    04 USP
    Las Vegas
    wheel bearing going bad?
    USP CLUB MEMBER #686
    Sep 14 2006
    Mass
    say i had like 10 coins in my hand. i shake them up and down once. thats what it sounds like in my left wheel when i go over a bump in the road. somethings loose, what, i don't know.
    -Max
    Dec 06 2007
    ^^check the dust covers for the brakes mechanic said take a long flat screwdriver and knock it with a mallet!
    -Kirk
    Veteran Member Three Rings prey's Avatar
    Feb 03 2007
    2003 Audi a4 1.8 TQMS
    Parsippany
    hahaha same thing here.
    Prey
    2003 Audi a4 1.8TQMS Unitronic Stage 1+
    Veteran Member Four Rings wolfdog's Avatar
    Nov 22 2006
    It's your brake pad rattling. Reach through the wheels and push on the inner break pad in a couple different directions, you'll hear it ping. You're fine with the rattle. If oyu want it gone, you'll have to take out the pad adn adjust the prongs in the back as well as put a bunch of antisqueal around the body to help stop metal/metal contact.
    2002 A4 TQMS
    Motoza 1+ w/Genesis 380s, 034 HFC, K&N drop-in, 710N, Neuspeed snub, StopTech SS lines w/Hawk HPS, Conti DWS, full Votex, Pioneer FH-X700BT, DDM 35W 4500K HID
    12/23/09 - My car has been phenomenal to me. Runs strong. Don't think I'm ever going to sell it. Rather throw $7k into it for a refresh than buy a new A4 that has no dipstick.
    12/5/10 - 100k miles & counting!
    9/22/13 - 146k+ & running strong w/a new TB, water pump, etc.
    Established Member Two Rings A4DJ's Avatar
    Apr 22 2008
    '05 S4
    Colorado Springs
    I was getting worried when I started hearing this noise.. this thread helps me rest a little bit easier... lol
