Results 1 to 26 of 26
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    Unhappy just installed the RaceTec and problems...
    Chris and I worked on the car allll day and I mean bout 10 hrs trying to figure this out. Obvious boost leak so we went back and checked alll the clamps and re-tighten everything. Have no idea what it could be and im stumped, drove the car home like a grandma
    any input is greatly appreciated!
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Oct 08 2005
    Orlando, FL
    Re: just installed the RaceTec and problems...
    also have had an oil leak for awhile not sure if its a broken hose or what but it seems to be coming from the intake manifold side possible pcv? I had the 3 way hose and the suction jet pump hose replaced so not sure if that might play a part in the boost leak at all
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    get on aim and ill try to explaiin/help
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Oct 08 2005
    Orlando, FL
    on my sisters mac book not sure how lol
    Jun 04 2007
    Austin/DFW, TX
    lol, well explain to me your oil leak. Did you see it on the floor right after you isntalled it? or is it constantly dripping everywhere
    My 5-Speed Swap DIY
    - B6 USP
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    You didn't exactly say what issue you were having after installing the FMIC.
    Jun 04 2007
    Austin/DFW, TX
    leaking something, and he says that his turbo spools but he goes no where. no boost guage
    My 5-Speed Swap DIY
    - B6 USP
    Oct 08 2005
    Orlando, FL
    when I go wot it spools turbo gets pretty loud and goes nowhere shifts kinda hard (tip) don't have a boost gauge yet the car is timid limp mode?
    Jul 07 2004
    socal
    Do you have a vagcom?
    Oct 08 2005
    Orlando, FL
    yes
    Mar 13 2006
    phil
    possibly a blown wastegate or bypassvalve?
    mine blew a wastegate/bypassvalve(forgot which one) and when i went WOT the turbo made a loud sound just as if i had an atmospheric BOV. and when decelerating, the engine dies.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    so when you put your boost leak tester in there, where does the leak come from? sounds like a leak somewhere
    Oct 08 2005
    Orlando, FL
    don't have a boost leak tester sounds lie the leak is on intake mani side at idle it goes pssssh pcv?? when wot it sounds lie a leak is coming from the turbo side
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    thats a bad engine!!!! lol
    wuz up man, havent heard from you ina while.
    try to get your hands on a boost tester, you`ll find it right away with it.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    yo man, ive got a boost leak tester. Ill help you out. I just used it today to help a buddy find a leak. Turns out a one way valve broke apart and casued a leak. How come your never at the sat. meet?
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Oct 08 2005
    Orlando, FL
    Quote Originally Posted by t1demont1 View Post
    dude that would be great! I wouldve have gone last night had the fmic worked out ok but was too tired. Lemme know ur schedule and We'll meet up soon! thanks again!
    Oct 08 2005
    Orlando, FL
    Quote Originally Posted by pipe7284 View Post
    whats goin down felipe? Ive been around kinda stayin low key for now just getting the car finished, comin along nicely! You think youll have ur beast running before the bbq??
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Quote Originally Posted by 20A4Audi1.8t01 View Post
    pmd
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    How did you install the diverter valve. The kit came with the supplied hose attachment but I cannot get it to connect from the diverter valve to the pipe. Now I tried moving the diverter valve in every direction to make it fit and it would not work so please dont tell me to move the diverter valve around. The pipe with the diverter valve nipple is facing towards the passenger wheel. Do I have it on the wrong way? Any help is appreciated. I could have been done a while ago but that is the last step. Please help.
    EDIT: Im thinking I need to turn the pipe with the nippel facing towards the engine. I ran out of time for tonight so I will try tomorrow. Also, getting that pipe to fit between the cooling lines and the smoke pump thing was a b**ch.
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    You have it the wrong way, just flip it
    {99.5 Avant}
    Oct 08 2005
    Orlando, FL
    Quote Originally Posted by VTAudiA4 View Post
    yes it was a bitch getting around the pumps had to trim some plastic to get the pipes to fit wish they woulda gave you one pipe just like the intake mani side but I have it facing toward the turbo doesnt leave much room at all the hose on the pipe is bent a bit because of no space really wonder if that would have anything to do possibly? not flowing efficiently??
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    i found that you have to really tighten the t clamps really tight cause i had huge booost leaks once my kit was installled.
    01.5 A4 1.8t sport
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Tyler, well get your car in order by the cook out ;). I got my vag-com hooked up again so we can do your vag mods when you stop by tomorrow if you want.
    Oct 08 2005
    Orlando, FL
    yeah man we can do the vag mods! just got back from eta dave tightened the coupler coming off the turbo because it was loose and replaced the torn vac line said I should get oem 386cc injectors because the siemens don't sit properly and low enough.
    Jul 07 2004
    socal
    You are using the fuel rail spacers?
    Oct 08 2005
    Orlando, FL
    yes I am just bought some 386cc from Manguyen hope it helps!
