Results 1 to 9 of 9
    Veteran Member Three Rings covertS4driver's Avatar
    Jun 11 2008
    2007 Audi RS4 (Gone), 2005 Audi S4 (Gone), 2002 Audi S4 (Gone)
    Dutchess County, NY
    Drivers window won't go up......already!
    Has anyone else had this problem? It just came out of nowhere!
    Window will start up, but immediately reverse. I started taking it apart, and then said..... wait a minute, CPO!
    But, how 'bout it? Anyone else?
    (I said "already" in the title, cause I just got the car! hahahaha)
    2000 Audi A4 Race Car, 2014 Audi SQ5 (Daily)
    Run Silent, Run Swift...
    Deactivated Three Rings
    Apr 11 2008
    Re: Drivers window won't go up......already!
    Does the window go all the way up, then down about a 1/4 way? If so, that's just your pinch mechanism.. sometimes it gets a little off. If it is, you can reset by holding your button all the way till it goes down, keep holding three seconds while its all the way down, then immediately hold till it goes all the way up, holding again about 3 seconds at the top. Should reset it.
    NOW, if the damn thing just isn't working period, it might be a regulator going bad.. i had a similar problem with my 04. Start listening for weird sounds (clicks, crackling, etc).. then you'll know the motor needs to be replaced (did someone say CPO!?).
    Hope this helps.
    Veteran Member Three Rings caitovS4's Avatar
    Nov 19 2006
    Most likely the regulator - very common.
    Do a search and you'll find plenty of others with the same problem.
    I've already had the driver's side replaced on my B7 S4.
    Jun 11 2008
    Dutchess County, NY
    Now it just won't go up at all....
    Maybe it is the regulator...
    Dec 28 2007
    2004 B6S4 6MT Nogaro
    Hoboken, NJ
    My C5A6 had the same problem on the passenger side front window...it would get "stuck" about half way up and go back down. Audi tried to fix it numerous times (and charged me $90 each time)...it would work for a month or two and then die again. I ended up just not using that window...ugh.
    Cheers,
    -Kurt
    2004 B6S4 4.2L Sedan (built 03/04, bought 09/07) | 6MT | Nogaro Blue w/ Black Leather w/ Blue Alcantara | CF Trim | 20% 3M Tint | AWE Non-Res Catback | 18" BBS RX | SportContact 2 (summer) | Blizzak LM25s (winter)
    2000 C5A6 4.2L Sedan (bought 07/05, retired 09/07) | Tiptronic | Ming Blue w/ Tan Leather | Wood Trim | Goodyear Eagle F1 GS-D3 (summer) | Blizzak LM22s (winter)
    Nov 07 2005
    RS6, M5
    Melbourne, Australia
    Quote Originally Posted by covertS4driver View Post
    That's what I'd be betting on.
    Feb 04 2008
    04 S4 6MT; 08 328xi 6MT
    Philadelphia, PA
    Same as kloover; happened on the passenger front window. Audi replaced regulator (they told me that the plastic piece doesn't wear well) and it has been fine since.
    Veteran Member Three Rings johntesi's Avatar
    Jan 17 2008
    Evolution X
    Texas
    How long does the regulator replacement take? I've had this problem for about a month, but I've been in and out of town so much that I haven't had a chance to take it in. Now that I've got new wheels and coilovers I am really hesitant to part with the car!
    Apr 11 2008
    Quote Originally Posted by johntesi View Post
    It's a pretty quick swap once they take off your door panel. No longer than 30-45 mins?? You'll be out of town longer than it would take, trust me.
