Results 1 to 13 of 13
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    injector issue... please help!
    i just got done installing my phenolic intake mani spacers and a new aux water pump...
    well i got everything put back together and i start the car to do checks and i hear this ticking. really loud ticking that comes after about 2 minutes of idling.
    vag com says cyl 3 mis fire.
    i reach down while the car is on and unplug injector 3 and the ticking goes away.
    do i have a bad injector?
    how the fuck could it just go bad from being taken out and put back in..
    grr
    Apr 05 2007
    Re: injector issue... please help!
    double check and make sure the o-ring is sealed and not pinched or anything. could be an air leak.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    i swapped cyl 3 injector with cyl 6 injector
    the ticking still stays at cyl 3 and vag com still says cyl 3 misfire. ....
    that pretty much eliminates a bad injector...
    any ideas?
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    low compression on cyl 3. motor is on its way out. 2.8 heads here i come.
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Wow...what the heck happenend?
    Brilliant Black 2001 S4 - 6MT <3
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by JackalS4 View Post
    i have no clue. ive had a misfire on cyl 3 for a while.. i couldnt get rid of it. im thinking i had this problem for a while. either that or my dumbass dropped something in the runner... but i dont think i did as i was very careful and the motor idles fine. either way i have 120psi on 5 cyls and 70psi on cyl 3
    motor will be out tomorrow and heads should be off by next weekend hopefully
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    did you do a wet compression test?
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Veteran Member Four Rings Silence's Avatar
    Mar 19 2004
    Vegas
    So no runs? J/k, that sucks. I had a cylinder 3 misfire that wouldnt go away too, but thankfully, turned out to be an injector.
    Cheers! David
    ____________________________
    Garage sale! Tons of A4/S4 parts available
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by SoEvoL View Post
    uhm.... i went to autozone and got a compression gauge that you screw into the cyls (where the plugs go) i unplugged all the coils and cranked the car and then went cyl by cyl.
    i have no idea what a wet compression test is...
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Before you take the whole motor out I would double check your work on putting in the spacers. If you didn't have a misfire before and then you install spacers and now you have a misfire I would suspect that something got installed wrong. Maybe a gasket is out of alignment.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by RolledMySTi View Post
    ive always had a misfire on that cylinder. im going to pull the intake off tomorrow to double check the work.
    would a misaligned gasket cause 50psi loss of compression on one cyl ?
    i honestly think i had this problem before-hand. i hope somehow the gasket is incorrect or something
    Dec 06 2007
    Calgary, AB, Canada
    The intake mani gasket shouldn't affect your compression at all if the intake valves are closed.
    Oct 31 2005
    Ashburn
    I remember when i was doing this install, didn't end well for me either.
    I was careful but not enough. When the car was back together i had misfire's on cylinder 2,4. Did a compression test and had bad really low compression in those cylinders. long story short. i spent enough money to be stage 3+ and i still have a troublesome stage2+.
    best of luck.
    - Instagram: @Sinister_rs5-
