i boost leak tested again today just to re check everything before EPL sends me another ECU to try out. i found a small split in my boost gauge line and a loose clamp on the y split from the bottom of the n75. fixed those. still misfires. checked the wastegate lines and wastegates and everything seems to check out. now when i turn down the boost to 14psi it will not misfire and i cant get it to pull codes. now turn it up to 15psi and it misfires immediatly and the CEL flashes and it stores codes. ive replaced and checked everything. i really cant help but think this is a ECU/software issue . my car lost communication with the diagnostics 3 times and 1 time i couldnt connect. gas gauge is starting to sway (replaced sending unit 6 months ago), coolant temp gauge is weird occasinally. i hate this car but i dont want to get rid of it. so my question is could it still be the ECU? i mean wouldnt the problem persist regardless of the level of boost? update:::: ok so i regapped to .022 and turned the boost to 24psi and the fucking car pulls like it should. zero hesitation and.......... wait for it........ then it starts to stumble. slowly but surely. here it comes again. what the fuck! it cant be a leak if i can get it to run great for 30 minutes on 24psi and then it slowly stumbles. colder plugs maybe?
