Results 1 to 26 of 26
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Putting on the RS4 pedal covers.
    Okay so last night, at 6pm, after work I decided to install the RS4 pedal covers. The estimated 15 minutes to install this thing is so way off that it isn't even funny. It may be that I've gotten a bit too portly and old, but it took a good 2.5 hours. But after 2 sore ribs, jacking the heck out of both hands and digits, they are on. Pictures to follow later. Most write ups about this, BTW suck. There are many things that are not mentioned. What the heck is an assembly grease? Anyway, here's what I would write on how to install these darn things.
    Pull the seat all the way back. Place a blanket or pillow on the door frame on the body of the car since your ribs will be hanging off of it for a long time, most of the time using it as support while you apply pressure to the pedals.
    Tools you need (yes, it is required!). Small flathead screwdriver, keyword would be short and sturdy. Don't use the "precision" set. If you have one of the stubby flat heads, you would be of an advantage, I didn't. I used a "sewing machine" type screwdriver, the one that looks like a pen with two screwdriver ends (philips and flat).
    Recommended or optional: I used Prolong penetrating lubricant, since I have no idea nor does my local Kragen and Autozone, what the heck assembly grease is. Hair dryer, in retrospect, I probably would have had a better time if I used one of these to soften the rubber.
    1. Remove the stock pedals, only the brake and clutch pedals have removal covers. I started with the clutch which was the hardest to remove. Using the screwdriver, get the blade between the rubber and the metal of the pedal and lift up to get the rubber off the pedals. Do it this until you loosen it enough to remove the covers. Brake pedal is by far the easiest to remove.
    2. Install the pedals. I started with the Clutch which was the toughest. Start by getting the top of the pedal covers on the pedal. Make sure the metal is on the rubber groove. Using one hand, hold down the top to keep the pedal from moving while using your other or free hand to use the screwdriver to work the rubber so that the metal is inserted into the rest of the rubber groove on the pedal covers. The brake pedal is the easiest, in that you will have more room and that it slips in much easier. Using the same idea, start with the top first and then the left, which is the more rigid since of the rubber. With top and left side secured, use one hand to keep it from moving and use the other hand to work the pedal in. The right side of the pedal is where Audi put the "stress reliever" side of the rubber, where it is workable and pliable. Find the slit in the middle right side and use that as a guide to insert the screwdriver and work down. Note that the brake pedal cover has a middle notch/tab that marries with the hole on the pedal itself.
    Accelerator or gas pedal. Start on top and get the right side secured. I had to stretch the left side fairly long to get it on the lower left side of the pedal. Holding the cover with one hand, work the screw driver to the lower 1 quarter of the pedal for the notch which you can insert your blade in and work outwards. Work it to the top. You're finished. Hopefully, yours won't take 2.5 hours, with some sore fingers and ribs.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    Re: Putting on the RS4 pedal covers.
    it took me 10 minutes dude..i soaked them in hot soapy water...2.5 hours...come on
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by SeKKeY View Post
    I kid you not, either mine was specially stiff, or I'm a clutz, but my neighbor, was timing me, lol. Glad it only took you 10 minutes. I have 2 sore ribs adn my finger hurt like hell...
    I was thinking of doing something like that, soaking it in water, but was afraid it may rust the medals later...
    USP Member 110
    Oct 15 2006
    From a few to one...
    Arlington, VA
    when i did mine, they were tough as hell. took me about an hour and i only got the dead pedal on. said fuck it, put it on and stomped it with my foot. turns out, that did the trick. got them all the way on, including the edges on the back. took like 10 minutes after that hour.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - APR Stage 1, Kohlefaser Luft-Technik Intake
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by nyteescape View Post
    when I Did Mine, They Were Tough As Hell. Took Me About An Hour And I Only Got The Dead Pedal On. Said Fuck It, Put It On And Stomped It With My Foot. Turns Out, That Did The Trick. Got Them All The Way On, Including The Edges On The Back. Took Like 10 Minutes After That Hour.
    Lolz
    USP Member 110
    Veteran Member Four Rings jsantiago17's Avatar
    Aug 07 2008
    2004 A4 Quattro3.0L UltraSport
    Westchester, NY
    I just ordered them and should get them by Wednesday....I'm hoping mine install as yours, Sekkey!
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Since they are made out of Aluminum they aren't going to rust so the soapy hot water is a good trick.. mine took about a half hour with just a flat head screw driver, I agree though it is a royal pain in the ribs..lol
    Senior Member Two Rings Dompiece's Avatar
    Jul 17 2007
    San Diego
    If you just soak the pedals in hot water for 10 minutes they will soften. They are still tough to get on, but it only takes about 10 minutes and a little elbow grease. There is no reason you had to suffer like that. lol
    Established Member Two Rings michpan's Avatar
    Mar 15 2007
    Athens, Greece
    The only pedal that gave me a hard time was the gas pedal. The installation of the foot pedal and the other ones were pretty easy without any soaking. After placing the bottom end of the cover over the gas pedal, I had to use a screwdriver as a lever to pull and widen the cover a bit in order to fit it properly. But still it didn't take more than 25 minutes-half an hour.
    Michael
    - Audi A4 1.8T B7 FWD+GT2x+carbonio
    + milltek exhaust+neuspeed xtreme tip
    + APR fmic+hofele bumper+ bilstein/h&r
    + votex rear spoiler/diffuser+DTM skirts
    + RS4 18' wheels+RS4 pedals+s4 mirrors
    Veteran Member Four Rings mister_tu's Avatar
    Sep 27 2007
    Boston, MA
    "Insert FAIL pic"
    Jan 13 2007
    '04 Audi A4 1.8T
    Arizona
    Took me a while too.. I had to have my girl get down there to finish the job.. I wish I would've soaked them..
    -T
    Jan 10 2007
    VA
    About 15 mins here. Hardest part was getting the stock clutch and brake covers off. Soften the RS4 pedals in hot water and work the edges on with a screwdriver if needed.
    Jun 15 2008
    Fairfield, CA
    In retrospec or hind sight which is 20/20, I should have soaked them. No instructions anywhere on the net indicated soaking them. It makes sense to soften the rubber, actually I should have either used my heat gun or my wife's hair dryer, but they are on now and they are not going anywhere. I also picked up the dead pedal and it is now a complete set. Looks awesome!
    USP Member 110
    Aug 14 2008
    '90 Cq - '13 R
    obamaland
    Just got my set today; I did the soapy hot water, and mash the pedals with my foot method, and it took 15 minutes.
    Oct 15 2006
    Arlington, VA
    Quote Originally Posted by beemercer View Post
    +1
    foot FTW!!!!!!!!...
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by NyteEscape View Post
    +1
    foot FTW!!!!!!!!...
    You guys must have some big a$$ feet to get that much pressure...I have some size 9.5's...
    USP Member 110
    Dec 06 2007
    ^^wow are u like 5 ft 2in?
    -Kirk
    BetaAlphaTau Member #58
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by AudiA4Turbo22 View Post
    LOL, a little taller...LOL Good catch with the proportions, Kirk... I'm Asian, they don't tend to make us very tall you know...LOL
    USP Member 110
    Dec 06 2007
    ^^so ur not yao ming? lol j/k at least ur race isn't blessed with big noses big enough to where a 747 could land on.
    -Kirk
    Jun 15 2008
    Fairfield, CA
    I'm guessing your Jewish? LOL BTW, you know that is not considered a race but a religion...right?
    USP Member 110
    Dec 06 2007
    ^^ur freakin Crazy, i'm Christian orthodox, but Armenians have huge noses.
    But i got ur comment LMAOOOO! Air is free.
    -Kirk
    Jun 15 2008
    Fairfield, CA
    Armenian? Wow, like Kim Kardashian?
    USP Member 110
    Dec 06 2007
    ^^haha ya but she's like a third generation Armenian, doesn't even know a word of Armenian which in my book=trash!
    -Kirk
    Veteran Member Three Rings tuner culture's Avatar
    Jul 19 2007
    1.8T Q 1+, Honda Odessy
    Florida
    Where did you get them from, and how much?
    2003 A4 1.8Tq
    19" RPM | Bridgestone Potenza RE960AS
    APR stage 1+ | Forge 007 | Kerscher | AWE | Race tec | RS4 pedals | S4 Grille |
    Jun 15 2008
    Fairfield, CA
    I bought the 3-pedal set on ebay from "Goingfast", she/he is a jerk, though that overcharged me on the shipping. I bought it for 179.99 + $20 shipping, it only cost them $8 to ship. Took freaking forever. Then I bought the dead pedal for ~160, IIRC, from 400HPA4 or bka Greg, here on the forum.
    USP Member 110
    Established Member Two Rings smarrick's Avatar
    Apr 07 2008
    04 A4 18T 6MT QT SPORT, 07 X3, 74 Lincoln Continental
    Fort Collins, CO
    Quote Originally Posted by 04QuattroTurbo View Post
    9.5 what are you guys in Junior High.
    I'm rolling 15's
