Originally Posted by
aaaudiprotein
15mm in the front? I got 235/45/17
How expensive is that usually to roll the fenders? Do u have to repaint the fender afterwards?
Well according to my calculations comparing to our 8.5" +38 wheels, if you plan on running a 15mm spacer in front of the already 7.5" +35, its going to bring it down to virtually a +20 offset and stick out 5mm more then a 8.5" +38 offset wheel. If you do roll your fenders, you should be fine with the extra 5mm. As far as the rear 20mm spacer might be a tad too large. Its probably going to rub.
-Charles@VMRWheels
www.vmrwheels.com
