Results 1 to 11 of 11
Thread: wheel spacers
    Registered Member Two Rings
    Dec 17 2006
    Boulder, CO
    wheel spacers
    Hay guys, quick Q. Trying to buy wheel spacers for a gift for a freind with a '04 S4. I know he wants 10mm. Were should I buy, and do I need longer bolts for him. Any info will help. thanks guys.
    Dec 05 2006
    So. Cal.
    Re: wheel spacers
    If you need them fast go with the H&R's. If you don't, go with the MTM's. Both are going to cost the same.
    MTM's are $155 and include new bolts
    H&R's are $95 and the bolts will run you $4 x 10 another $40.
    That is for a pair, one box, two wheels!
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    Re: wheel spacers
    i have a set of motorsport techs 10mm dual drilled 5x100/112 hub centric (57.1)spacers. never used i'll sell for $70 shipped. buy the bolts from ecstuning.com for $2.95 a bolt and it will cost about as much as just the H&R spacers
    Nov 04 2006
    05 S4
    LI, NY
    Re: wheel spacers
    buy at ecstuning.com you can get a kit that comes with the longer bolts needed and the spacers. plus they have all sizes incase you wanna get 12mm or something like that.
    Oetty roof spolier // FI Catback // Ecodes // Xenon Interiors // Solaris and LED Exteriors // Lower Euro-grille // ECS Snub // PSS9s // 19x8.5 BBS CH on 245 Potenzas // Euro RS4 Exclusive shift knob and Pedal Set // Carbon Fiber Trim // Custom Carbon Fiber Emblems
    Originally Posted by Justincredible
    "With the flux mod you can just put the supercharger in the trunk for extra traction"
    Feb 16 2008
    08 Mini, 04 A6 2.7T
    Renton, WA
    Re: wheel spacers
    Try Achtuning. They are very honest and will stay on the phone forever to explain every bit of detail. I went through 3 sets of spacers and Achtuning finally got it right. I got the 15mm and 20mm H&R DR series with extended bolts for a little over $200 shipped. Good luck.
    Veteran Member Three Rings covertS4driver's Avatar
    Jun 11 2008
    2007 Audi RS4 (Gone), 2005 Audi S4 (Gone), 2002 Audi S4 (Gone)
    Dutchess County, NY
    Re: wheel spacers
    Not to hijack this thread, but what is the most popular spacer to run? Is it 10mm?
    Just wondering what everyone thinks...
    2000 Audi A4 Race Car, 2014 Audi SQ5 (Daily)
    Run Silent, Run Swift...
    Veteran Member Three Rings ZachPDX's Avatar
    Jun 09 2008
    PDX
    Re: wheel spacers
    Quote Originally Posted by covertS4driver View Post
    I think this is my next mod, guess it depends on your wheel but seems like most rock the 10's, ive seen a few people post that they have 8 in front and 10 in the back but no pictures
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Re: wheel spacers
    Stock Avus with 15mm
    Lowered to 25.5" no rubbing.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Jun 09 2008
    PDX
    Re: wheel spacers
    Quote Originally Posted by S4J View Post
    hrmmm.... looks like ill be getting 15mm instead. Any more?
    Senior Member Two Rings Escargot's Avatar
    Jan 09 2008
    '59 MGA 1500, John Deere
    Bucks County, PA
    Re: wheel spacers
    While we're on the topic...what are people running on their B7s? Same?
    Established Member Two Rings tileg's Avatar
    May 01 2008
    Philadelphia
    Re: wheel spacers
    just put on 10mm front and rear.
    kinda regret not getting something bigger for the rear. oh well.
