Results 1 to 3 of 3
Thread: Rough Idle
    Registered Member Two Rings
    Jul 09 2008
    Napa, CA
    Rough Idle
    Hello, I own a 2000 A4 1.8T Quattro Tip. I notice that when I come to a stop my car idles a bit. Nothing horrible but you can def. tell its not normal. I was told to clean the throttle body. How do I clean that? Also when searching it also said to clean the Idle control something???. I saw the instructions but it was for a different model and engine. Some help please. Thank in advance
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    Re: Rough Idle
    thats the Throttle
    remove the hose by loosening the 7mm hose clamp, and bending the hose out of the way.
    to clean it:
    use a throttle cleaner from an auto supplier and a rag. spray the TB with the cleaner, and spray some on the rag, then open the throttle blade(if you push in towards the bottom it will flip open) and clean the blade and surrounding area. there shouldnt be any black left when you are done.
    the car may not want to start, or idle roughly when you are done. thats because of the throttle cleaner in the intake. it will burn off after a few seconds.
    Jul 09 2008
    Napa, CA
    Re: Rough Idle
    Sorry for the late response. Thanks I will try that.
