Results 1 to 6 of 6
Thread: CQ skins
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    Lightbulb CQ skins
    Normally I'd do the calculations myself but I am unfamiliar with the OEM tyre size on the '90 CQ... so here's the question:
    - I've got two sets of good rubber for my A4 that I am kind of hoping will transfer to the CQ I'm going to be purchasing soon. I've got summers and winters in 235/45-17... am I in luck?
    TIA
    2013 Touareg TDI Execline /// Farmenwagen: Malone 2.5 tune, Darkside & Rawtek Delete
    1992 80 quattro 20v /// Eventual AAN'd Winter Sled
    1990 Coupe quattro /// Because Racecar
    Veteran Member Three Rings chucka4's Avatar
    Feb 18 2004
    1995 audi s6
    pittsburgh pa
    Re: CQ skins
    nope, unless you buy 17s for it. the coupes come with 15s, stock. and i think the bolt pattern is different also
    1996 audi a4-gone to a airplain malfunction
    1998 audi a4-sold to a simple farm boy
    1990 audi CQ-dont buy a car that is not from the US
    1990 audi 100-mistake and distroyed
    1995 audi s6- the new hawtness of sexytown
    Jun 28 2007
    Edmonton, AB
    Re: CQ skins
    Well purchasing 17s wouldn't be bad, but I'm looking to keep within the +/- 3% range... so do you happen to know the OEM rubber size?
    Do you recall the bolt pattern? 5x100?
    Senior Member Two Rings branden's Avatar
    Dec 18 2006
    Minnesota
    Re: CQ skins
    Correction: 4x100
    Stock: 205/60 15
    However 17's look the best on the CQ. Not too big, not too small but JUST right! :D
    Veteran Member Four Rings snopyro's Avatar
    '08 TT 3.2q Roadster (for sale), '20 A7, DC Taco, SV650s, lots of snowboards
    Re: CQ skins
    OEM CQ bolt pattern is 4x108 with ET35 or is it ET37.
    The difference between the OEM 205/60-15 (817 revs/mile) vs. 235/45-17 (796 revs/mile) is a 2.6% difference.
    So the 17" tire would be bigger and your odometer mileage would be less than actual.
    Go here to play with Tire sizing calculations:
    http://www.miata.net/garage/tirecalc.html
    Jun 28 2007
    Edmonton, AB
    Re: CQ skins
    ^^^ Thanks, I actually just looked it up from the Owner's Manual after I bought the car.
    EDIT:
    Had a snap-snowstorm last week, wanted to share my impressions of my new tyres.
    Installed four new Nokian WRG2 195/65R15. I won't be buying 17s for the car anytime soon so I found a set of all-weather tyres I'm confident in... which says a lot because I often scoff and scrunch my face when it comes to all-seasons. But these are different.
    I've got Dunlop SP 3Ds on my A4, and they're excellent.
    Maybe it's the fact that they're narrower or the CQ has more clearance, but my first impression of the the WRG2s is that they're equally as good -- a bit better braking wise but not quite so good under hard cornering -- as the Wintersports. I ripped through fresh drifted snow like a hot knife through butter. Taught braking on very icy and steep residential roads. Can't wait to get them broken in fully and into the mountains.
    (PS. I went with an aggressive winter-based all-weather because I snowboard in the winter and camp in the middle of nowhere come summertime.)
