Results 1 to 17 of 17
    Veteran Member Three Rings mwbunns4's Avatar
    Feb 20 2008
    2011 Audi S4 6MT, Audi A3 TDI
    Savannah, GA
    possible boost leak....hose kit??
    so i think i have a boost leak. my boost spikes at 20 then drops down to about 13. i dont have any kind of aftermarket hoses (TBB, F hose etc.) i am looking into purchasing a kit now, anyone know where i can get a quality kit for a decent price? thanks
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: possible boost leak....hose kit??
    Quote Originally Posted by mwbunns4 View Post
    http://www.ecstuning.com/stage/edpd/...l=&engine=2.7T
    Pressure test the car too
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    pressure test the car first before wasting a bunch of money.
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Feb 20 2008
    Savannah, GA
    is there a good source that thoroughly explains how to?
    Jan 29 2007
    08 S4 00 S4
    MD
    http://www.awe-tuning.com/media/pdf/...ure_tester.pdf
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    easiest thing to do even before pressure testing it is check your TBB and F hose (if you have one) thoroughly. if those are rip free, then pressure test.
    ThorTechnik.com
    Registered Member Two Rings mistert396's Avatar
    Apr 23 2007
    2001.5 S4
    Ft. Bragg, NC
    Quote Originally Posted by S4evr View Post
    x2
    I just replaced the throttle body boot and I was having the same problem as you at first. Where about in NC are you at?
    Stage I
    GIAC, 710n, Darintake, JHM Tranny rebuild, Cheapo Ebay Short Shifter, Vast Stage 2 Clutch, APR Vent
    Feb 20 2008
    Savannah, GA
    im at fort bragg. fayetteville.
    Feb 20 2008
    Savannah, GA
    what exactly is the F hose? i think i have an idea...
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    samco kits FTL. wayyyy too much money. and didnt they go out of business?
    go to ebay, type in "audi s4 hose kit", i believe the company is ASI. you can get a full kit for $165 shipped. its what i have and they work beautifully,just the same as Samco without the name brand.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Pressure test first before you buy anything. Do you have a boost gauge? What does it read at idle? It could be your N75, but pressure test before you spend a dime.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Established Member Two Rings Talon Load's Avatar
    Jun 23 2008
    '05 M3 Vert, '10 VW TDI Cup, '11 Grand Cherokee
    NC
    Well, I guess I'm the third Fayetteville guy with a possible boost leak. I hooked up my palm to the car today and found 3 misfire codes in the system. I also think I smell buring oil, but I'm not sure on that one. I need to get under the car once it's cools off and check it out. Have any of you tried the AWE way of checking for a boost leak or is there a good place in Fayetteville to have it done?
    Feb 20 2008
    Savannah, GA
    i dont know of any good euro shops around here, and honestly wouldnt wanna trust anyone in fayettenam. im gonna piece the tester together, is anyone close that has access to air?
    Jun 23 2008
    NC
    I've got a compressor, but not sure it would be right thing for it. We could use the Pope hobby shop. I know they have one.
    Feb 20 2008
    Savannah, GA
    all we need is an air compressor, from what i understand
    Jul 06 2007
    San Jose, CA
    Pressure testing is easy. Just follow AWE's directions to making a pressure tester and get an air compressor. You can buy a small air compressor at Wal-Mart for cheap. It's not going to power air tools worth a damn, but it's cheap and handy.
    Jun 23 2008
    NC
    If any compressor will do then I have one. I just need to go and get a quick diconnect. May need to get the parts to build me a tester.
