Results 1 to 8 of 8
Thread: Buynig a K04
    Dec 23 2007
    Queens, NY
    Buynig a K04
    Ok Im meeting a guy to buy a K04 -15 turbo today for $300. I would just like to get a list of questions that I should ask him about this turbo before buying. TIA
    1999.5 1.8t
    Carbonio - APR R1 Diverter Valve - TT Carrier - 12.3 One Piece Rotor - Stainless Steel Brake Lines - Podi Boost Gauge - More to come-
    Jul 02 2008
    1999.5 A4 1.8T Quattro
    Danbury, CT
    Re: Buynig a K04
    Check for too much shaft play and also check and make sure the wastegate is in working order and that the fins arent all messed up.
    Mialage?
    How much boost he was running?
    Dec 23 2007
    Queens, NY
    Re: Buynig a K04
    Quote Originally Posted by AEB A4 View Post
    Mialage?
    I know Im a noob but how do I check for those things like shaft play and the wastegate.
    1999.5 1.8t
    Jul 02 2008
    Danbury, CT
    Re: Buynig a K04
    for the shaft play just wiggle the shaft that has the finns on it and see if it hits the compressor housing anywhere while turning the shaft. and make sure the wastegate flap is not melted and make sure that it makes a good seal when you open and close it. Also make sure the wastegate actuator and shaft are not loose and soft when trying to open the wastegate. thats kind of a rough description on how to do simple checks on the turbo.
    arent you on vwvortex/fortitude ??
    Dec 23 2007
    Queens, NY
    Re: Buynig a K04
    Im going to print this out and take it with me. Thanks and no Im not on those forums sorry.
    1999.5 1.8t
    Dec 23 2007
    Queens, NY
    Re: Buynig a K04
    I officially got a k04-15 turbo sitting in my trunk for my baby.
    1999.5 1.8t
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    Re: Buynig a K04
    ^^^ and in a few days you gonna want BT :P
    GIAC-X, STASIS TS,VAST,034 MS
    Registered Member Two Rings
    Apr 13 2008
    Westlake, OH
    Re: Buynig a K04
    I want to go k04!
