Results 1 to 20 of 20
Thread: Bad Idle
    Registered Member Three Rings Firefighter637's Avatar
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Bad Idle
    When I start my car up from a cold start, and put it in drive or reverse and take my foot off the brake it wants to stall. The RPM's jump between 800-1000. After a few mins when the car is warmed up it's ok. Changed all the spark plugs and still having problems. Car only has 31k. Ideas? Suggestions?
    A4 B6 1.8T USP Silver
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Deactivated Three Rings
    Apr 11 2008
    Re: Bad Idle
    Rough idle usually indicates MAF/02 sensors or coilpack issues. Did you check your trim levels? I would start there first.
    Oh and I was looking for some pics of your crazy red interior in the other post a while back. You ever get photos of that? I'm still on the fence about doing this..
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: Bad Idle
    Quote Originally Posted by swrt83 View Post
    Copy that. What do you mean by the trim levels? I will take pics tonight!
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Apr 11 2008
    Re: Bad Idle
    Your trim info tells us if your engine is running rich or lean, depending on the amount of fuel/air mixture. Just hook into the vag com, engine module, block 32. Your %'s should be within -/+ 10% for normal healthy firing.
    General info here: http://wiki.ross-tech.com/index.php/Fuel_Trim_Info
    Here is an example (my output):
    Address 01: Engine (8E0 909 559 L)
    Group 031: Lambda Control (Lambda Sensor Voltages)
    1.000 Lambda Control Bank 1 (actual)
    0.945 Lambda Control Bank 1 (specified)
    1.000 Lambda Control Bank 2 (actual)
    0.945 Lambda Control Bank 2 (specified)
    Group 032: Lambda Control (Mixture Adaptation)
    0.0 % Adaptation (Idle) Bank 1 Sensor 1
    -2.3 % Adaptation (Partial) Bank 1 Sensor 1
    -0.4 % Adaptation (Idle) Bank 2 Sensor 1
    0.0 % Adaptation (Partial) Bank 2 Sensor 1
    Group 033: Lambda Control
    0.0 % Lambda Control Bank 1 Sensor 1
    1.520 V Sensor Voltage Bank 1 Sensor 1
    0.0 % Lambda Control Bank 2 Sensor 1
    1.540 V Sensor Voltage Bank 2 Sensor 1
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    Re: Bad Idle
    when my n80, braided hoses, and check valves were toast i had nasty idle and hard starts. fixing up everything put it back to normal. gotta do alot of PM when the cars get some age on them man or they start running like butt.
    i still haven't figured out why my dinan stage 2 335i is getting the same mpg as my apr stage 1+ ??!! i took great care with all the fluids (tip/brake/synth 5k,plugs 5k, tire pressure 38psi) tried everything. trims were fine. new o2 wideband. maf cleaned and verified gm/sec against other cars to ensure maf was flowing properly. never did figure it out :(
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Jul 11 2008
    chicago
    Re: Bad Idle
    i had i similar problem with my a4 b6 that i just bougth a couple months ago, rough on idle when it was cold, but after looking around i found a vacuum leak one of my check valve was broken in half i think the part number is
    A60 133 528A and is located somewhere between firewall and intake manifold, sorry don't have any picture but try looking between your vacuum hoses turn car on and gently move hoses a little bit to see if u find any hissing.
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: Bad Idle
    Quote Originally Posted by viajero22 View Post
    Yea, car is running worse now. Idle is bad when starting up. I'll see if I have any leaks. I guess it will be noticable if I do find one.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Mar 02 2008
    NJ, USA
    Re: Bad Idle
    Amazing. I just had the same rough idle problem, and found the same cracked vacuum valve that viajero22 mentioned.
    But in looking around for the part online, I can only find p/n ---133529A for about $17, which is called a vacuum check valve and looks like the right part, but its not 133528A (which is the number molded on the part).
    Were you able to find it online, or did you get it from the dealer?
    Jul 11 2008
    chicago
    Re: Bad Idle
    i had i hard time finding this part on line and since i wanted the part quick i had to go the dealership audi dealership was asking 72 and vw dealer was asking 55 for part so guess where i went, when i got the part they gave me one with part #A60 133 528D which is suppost to be an update
    Mar 02 2008
    NJ, USA
    Re: Bad Idle
    Aha -- the "D" was the answer (searches using the "A" part turned up nothing) and I easily found it online for about $37. Its called a Crankcase Vent Valve.
    Thanks viajero22!
    js.
    Registered Member Three Rings SlappyB6's Avatar
    May 14 2008
    W-S, NC
    Re: Bad Idle
    What do you consider bad idle? I ask because since I've put my TP on, when I first start the car, it's idles around 1100 RPMs, then after about a minute it drops back down to around 900. Is this normal, or should I be checking for leaks and/or rich/lean conditions? It doesn't idle rough, and I don't notice any smoke or heavy deposits, or marked differences in gas mileage.
    02 A4 - 5spd - Sport - VM DP
    Capt. Obvious - "Not me. I fart rainbows, shit rose pedals and piss excellence."
    Apr 11 2008
    Re: Bad Idle
    Quote Originally Posted by SlappyB6 View Post
    Seems normal to me, the idle regulator is supposed to start high and gradually come down once the car is warm.
    May 14 2008
    W-S, NC
    Re: Bad Idle
    Cool, that's all I wanted to know. Thanks.
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Re: Bad Idle
    Can you guys post a pic of the crankcase check valve and it's relative location under the bonnet? I would like to check mine, since my idle has been a little rocky lately, funny thing is that the tachometer has been steady. Happens cold or warm.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Mar 31 2008
    2003 A4 Cab
    Northern California
    Re: Bad Idle
    This is a worst case scenario, but on my 03 3.0 cabriolet I was having rough starts in the morning too. After the dealer replaced pretty much the entire fuel and electrical systems, they got into the motor and found that the cylinder sleeve was shrinking and leaking a tiny amount of coolant into the engine (don't quote me on this, it's the way the dude explained it to me) and making the car run like poop. When the car warmed up tho, the sleeve expands and the car runs like a champ. I guess this isn't the first time they've seen this happen. Long story short, they're replacing the motor (thank god for extended warranties), and I hope this isn't what you've got going on.
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: Bad Idle
    I checked my engine bay for vacum leaks and didn't find any. Now I guess I will clean the MAF with the cleaner and see what that does tomorrow. Hopefully its that. Tired of the idle problem!!!
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Jun 15 2008
    Fairfield, CA
    Re: Bad Idle
    Quote Originally Posted by Firefighter637 View Post
    So it the idle actual erratic? Meaning RPMS change and don't stay at 800 at idle?
    USP Member 110
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: Bad Idle
    Quote Originally Posted by 04QuattroTurbo View Post
    When the car is in neutral or my foot is on the brake the idle is around 800 steady. It's when I take my foot off the brake or put it in drive or reverse the idle goes down and acts like it wants to stall and shutters. Especially on a cold start!
    Update: Cleaned the MAF and changed the spark plugs.. runnin like shiot.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Re: Bad Idle
    Could it be your transmission? Seems like the computer is thinking it should be at normal idle, but the transfer to the transmission is taking more out of it, thus the lower rpms. Have you changed your transmission fluid?
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    May 03 2008
    A4 B6 USP
    Orlando, FL
    Re: Bad Idle
    Quote Originally Posted by aaronz View Post
    No I haven't changed the fluid. Haven't changed the O2 sensor yet either.
    GIAC-Flashed
    Forge DV
    De-Badged
    Blacked out Grill
    Clear Corner mod
    APR Snub Mount
    RS4 Rear Sway
    LED Tailights
