Results 1 to 30 of 30
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    Do I need new lugs for..
    Putting my OZ SL's on tomorrow for waterfest next weekend, can I reuse the stock lugs or are they two small? I believe the wheels are ET 32 or 35, isn't the stock USP ET about the same? Thanks.
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Re: Do I need new lugs for..
    usp wheels are most likely et40 or 42
    TEAM|AXION
    Sep 14 2006
    Mass
    perhaps someone can help me out since I don't know if these will be long enough. I have stock lugs and then some longer ones. I'm pretty sure the stock ones won't be long enough but maybe the other ones are..? how long do the lugs need to be for the OZ SLs? Here's a pic for comparison:
    Stock on right.
    -Max
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    My OZ wheels use a ball seat (not conical). But it's a different radius ball seat than stock wheels. Here is a picture to explain.
    http://forums.audiworld.com/wheel/msgs/65922.phtml
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Check your wheels first, most aftermarket wheels are cone seating and OEM wheels use ball seating lug bolts. Other than that, offset should have nothing to do with you needing longer lug bolts, if you have a spacer then you would need longer lug bolts. Also keep in mind the stock lug bolts are not meant to last forever, you are supposed to replace them after a while and yours definitely look in need of replacement.
    27mm is the length of the OEM lug bolts, just in case.
    Sep 02 2005
    Montreal
    Quote Originally Posted by akaEsCo01 View Post
    Negative, my OE wheels are cone seat.
    Dec 08 2006
    Jersey
    If you don't mind me asking, what wheels came with your car? My USP, my friend's sports package wheels and my boy's B7 all use ball seating which is why I posted that.
    Sep 02 2005
    Montreal
    The most baller' stockers of am all, the standard 15" (all other wheel sizes are considered optional on MY03)
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    To the OP, you'll need longer lugs for the OZ wheels (ball seating). The OEM lugs are too short due to the offset.
    My OEM USP wheels use ball seat lugs as well, but are short due to the offset (ET43).
    USP CLUB MEMBER #34
    Registered Member Two Rings limeylee's Avatar
    May 29 2008
    I just went through this with my SL's.
    ended up using 35mm (thread length) ball seat lugs.
    Wheels are a 32 offset.
    I have one set each (ball and cone seat) 30mm lugs left over from my experience if anyone is interested.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Wheel Stud Kit FTW
    With OZ SL's.
    Conical and Ball Seat with Studs
    Jun 30 2007
    Raleigh, NC
    mike where'd you get that and how much? it'd be AWESOME to have something like that...
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Why does Audi even make our cars with bolts? Why not studs...its clearly easier!
    -Sami-
    Dec 08 2006
    Jersey
    You answered your own question, because it is easier lol
    Jul 07 2004
    socal
    Quote Originally Posted by B6Lovin View Post
    I will have to take the 5th on that one.
    Veteran Member Four Rings IceMole's Avatar
    Oct 09 2007
    E46 M3
    PA
    -Kris
    Sep 14 2006
    Mass
    it looks like the second set I have will do the trick. is it okay that they are conical and not ball seat, they measure 35mm which is long enough it seems.
    -Max
    Veteran Member Four Rings B6driver's Avatar
    Sep 14 2006
    XBOX LIVE GAMER TAG: b6driver
    Eagle Rock, LA, Ca
    you shouldn't need new lugs if:
    -you are not using spacers
    -the lug seat matches the current wheel
    common misconception is that offset somehow affects lug size. offset usually refers to spoke design
    2004 A4 1.8 Turbo 5 speed gone...
    2010 Candy White VW CC R-Line
    Jul 07 2004
    socal
    Quote Originally Posted by B6driver View Post
    You missed the fact that not all wheels are the same thickness which is why the OZ's need a longer lug.
    Veteran Member Three Rings RED1.8T's Avatar
    Jan 19 2007
    Columbus, Oh
    A4TUNE - I don't know if this would help you or not, but I have a set of lug bolts for sale; they are zince plated and 14x1.5 Ball 26mm Shank, PM me if you might want them. I can get them to you ASAP
    Sep 02 2005
    Montreal
    http://www.shop.dthaus.com/product.s...5&productId=64
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The stock lugs have 27mm of thread and they protrude 20mm out from the back of the wheel. You need to find lug bolts in the correct configuration (ball or cone, depending upon the wheel seat type) that will give you a minimum of 20mm penetration into the hub. Just stick the lug bolt into the wheel and measure how much it sticks out from the back of the wheel. If it is at least 20mm you are good to go. If it is more than 20mm it will still work as long as it isn't long enough to contact the hub carrier. If it is more than 25mm of penetration just mount the wheel and give it a spin by hand to make sure that there is no interference.
    Cheers!
    Sep 20 2006
    Baltimore
    Wheel studs make life so much easier.
    Jul 07 2004
    socal
    Quote Originally Posted by skeeball View Post
    In so many ways.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Quote Originally Posted by A4TUNE View Post
    It's fine if you want to irreversible damage the mounting holes of your wheels.
    Conical seat bolts on a wheel that uses ball seat bolts is only asking for trouble. Lugs won't seat properly, and thus won't hold torque correctly.
    As mentioned earlier, OZ wheels use an R12 ball seat 36mm length bolt.
    ALL factory Audi wheels use an R13 ball seat 28mm length bolt. If your car came with something other, you have the wrong bolts.
    Sep 14 2006
    Mass
    Well I installed the second set of lug bolts I had and they worked fine. I will be purchasing the correct lug bolts relatively soon, should I buy them straight from OZ or what? these will work fine until after waterfest..
    -Max
    Sep 20 2006
    Baltimore
    Switch to studs. Mike can sell you the OZ nuts. I believe he sells the lug bolts also, if you go that way.
    Sep 02 2005
    Montreal
    I'd buy a stud kit, but only if it allowed 12mm spacers.
    Jul 07 2004
    socal
    On what wheels? I think that is pushing it on a set of OZ's which already need longer bolts, but maybe it would work on a wheel that can use shorter bolts without spacers.
    Sep 02 2005
    Montreal
    12mm longer than stock (27mm) so, 39~40mm.
