Results 1 to 6 of 6
    Senior Member Two Rings jman8806's Avatar
    Jul 23 2007
    99.5 b5 1.8tm, 1986 nissan z31
    Vegas
    limp/safe mode? no boost at all =[
    ok i've been searching for this problem the past 3 days.
    i cleaned my maf, replaced spark plugs, disconnect the batt and ecu. clean my filter/CAI and still having the same problem.
    heres the problem when i drive boost wont even hit, it wont even let is past 1psi =[.. this happened when i was drivin home from work on monday in las vegas heat it was about 108-112 out side. it felt like a big turbo lag. i thought it was heatsoaked so i pulled over too cool of for a bit and it still was having problems. and now im thinkin im in limp/safe mode.
    and i know its not the turbo because its still pretty new.
    i got a ko4pc16 set up with the injectors and everything, godspeed fmic, hks cai.
    i took it to autozone to see if i can get some codes but nothing came up. no CEL or anything.
    any help would do...pleeeaseeee and thanks in advance
    1999.5 audi b5 1.8tm
    [euroBREED]LV
    www.twitter.com/jman8806
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: limp/safe mode? no boost at all =[
    Well, limp mode would give you at least 5psi. Any abnormal sounds?
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    Sounds like your wastegate actuator on the turbo went. I had the same symptoms.
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    I'm guessing you have a boost gauge, and its reading normal vacuum?
    ÖMGHI2Ü
    Photography
    Jul 23 2007
    Vegas
    Quote Originally Posted by Yaktizzle417 View Post
    yea i was thinking my wastegate went out. and yea my boost gauge is reading normal vac
    [euroBREED]LV
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    Yeah definitely check your wastegate.
    Lol, when mine broke, the plunger would fall back into the vent. So it was like DSM style'd cranked wastegate.
    ÖMGHI2Ü
    Photography
