    Veteran Member Three Rings nrowensby's Avatar
    May 04 2008
    1999 Porsche Boxster
    Columbia, SC
    GIAC Chip Problem?
    Okay... I have two ECU's one chipped... one stock. When running the GIAC chip, my car will occasionally just shut off. Sometimes it while sitting at a stop light, sometimes when I am cruising down the road at 40, other times while I am doing 80 down the interstate... I see no pattern, it's just like a random shut off... no CEL's.
    Any ideas? I have never had a problem with the stock ECU...
    ▄▀▄▀▄▀▄▀▄▀▄▀ B8.5 Squad ▄▀▄▀▄▀▄▀▄▀▄▀
    2014 Audi A4 - Stg2 - Monsoon Gray Metallic
    2015 Audi A4 - S-Line - Ibis White
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Re: GIAC Chip Problem?
    Maybe your chip is disconnecting from the encryption board occasionally....
    Senior Member Two Rings mpower's Avatar
    Feb 02 2008
    01.5 Nogaro B5S4, 2012 B8S4 Glacier Prestige, 09 Q7 S-line TDI
    Chicago
    Had the same problem with APR chip due to bad/loose soldering. Was getting a CEL though....intermittent power to ECU and could hear clicking sound under the dash. After shipping the ECU to APR for re soldering all was well.
    May 04 2008
    Columbia, SC
    How much did that run?
    Deactivated Four Rings
    Jul 16 2007
    2000 A4 Avant 1.9L BT
    Irvine, CA
    As previously noted, it is likely a loose solder joint causing an intermittent signal from the chip socket to the ECU. I have a solution for you. Check your PMs.
