Just gonna go over everything again, in full. If you can provide any support I'd be in a whole lot of debt to you, as I've been trying to figure this out for weeks now.
Car is a 1998 A4 1.8T (AEB) with a K04, fmic and PC-16 setup. When running good the car spiked 21psi and held 17-18.
2.5 month ago - Spark plug failure @ Show n' Go. Bent a few valves, had to rebuild head. Initially thought I had a failed MAF, put new MAF in and just put the old MAF in the basement.
1 month ago - Car doesn't start, MAF signal too low code. Put in old MAF and car runs ok, but now only boosts ~5psi. Tighten some hose clamps and car now holds 14psi. Car runs a little rich I believe, definite loss of power. Boost onset is very weak.
2 weeks ago - In effort to solve boost issue, replace original MAF with new MAF from Audi (a replacement to the failed new MAF). Car still runs bad. Accidentally tear TIP.
1 week ago - APR TIP installed.
Today - New N75. Drive the car up the street and it craps out on me again. Roll it back down the hill (thank god I live on a hill), replace the MAF and it runs ok again. However, still only boosting 14psi.
So a list of what I've done:
- After going through 2 new MAFs, original MAF is in the car. Reads 160g/s at full throttle.
- Replaced N75C valve.
- Checked for boost leaks, system is sealed.
- Tried running car with no MAF, runs like crap. Tried running car with no TPS, doesn't run.
- Disconnected line from N75 to wastegate, still doesn't hit above 14psi.
I'm coming to the conclusion that its something with the turbo...
. Does anyone have any other suggestions to diagnose this, or any good turbo shops that I can ship the K04 to and have checked out?
