Results 1 to 20 of 20
Thread: Plugs
    Veteran Member Four Rings andru1313's Avatar
    Apr 13 2007
    Audi 2018 RS3 2006 Evo IX MR
    Frisco, Texas
    Plugs
    What are the best spark plugs to run for Stage 2+? I am going to be doing some service work on the car and just want to do it all at once. Thanks.
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    Re: Plugs
    i only hear good things about the bosch side fire spark plugs...
    Apr 13 2007
    Frisco, Texas
    Re: Plugs
    thoughts on going a grade cooler on the NK's?
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Plugs
    i had the grade cooler when i was 3- for a while (6 months) i had some misfiring at idle issues.... NOW switched over to side fire F5DPOR plugs (bosch platin side fire) and my exhaust note actually changed, engine runs much smoother etc. very happy with them.
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Re: Plugs
    anybody else with some experience with these...?
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Feb 17 2008
    Ottawa Ont.
    Re: Plugs
    I really dont like the construction quality of these things. I know they are being used, but the ground strap weld is crap.
    Jul 01 2008
    here n there
    Re: Plugs
    I hear this is the way to go, helps avoid pre detonation i belive.
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    Re: Plugs
    Quote Originally Posted by BastardS4 View Post
    the bosch ones?6
    -Luis
    Veteran Member Four Rings raketeS4's Avatar
    Feb 14 2006
    2000 B5 S4 Stg II+, 1977 BMW R100/7
    Re: Plugs
    I've been very happy with my NGK BKR7E's. They cost $2/plug and that's hard to beat
    2000 B5 S4 Stg II+
    Apr 13 2008
    Tennessee
    Re: Plugs
    depends on who's software you have
    Giac is actually tuned for stock plugs.
    Dec 06 2007
    Calgary, AB, Canada
    Re: Plugs
    Your Bosch plugs are one range cooler than stock as well...
    Senior Member Three Rings SoEvoL's Avatar
    May 11 2008
    2001.5 S4
    Bama
    Re: Plugs
    Quote Originally Posted by raketeS4 View Post
    x2, you change yours with every oil change?
    Keep It Simple
    2001.5 Silver S4 Stg 0.5 or 1-
    Mar 08 2007
    Mr. Worl-Wye
    Re: Plugs
    Quote Originally Posted by SoEvoL View Post
    daaaamn. definitely not my slice of pie^^^
    So between this and the other threads I've read, I think we've got the following (in relative order of cost, longevity, and misfire resolution):
    1. NGK PFR6Q's
    2. NGK PFR7Q's
    3. NGK BKR6E's
    4. NGK BKR7E's
    5. Bosch F6DTC's
    6. Bosch Platin F5DPOR "Side Fires"
    ...and gapped at 0.028" (with the exception of the F5DPOR's that come pregapped). Obviously this is a very subjective topic, but does the ordering appear generally correct?
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Nov 20 2007
    Murfreesboro, TN
    Re: Plugs
    I recently changed my plugs to the NGK BKR7E's and now I have random misfires. I am Stage 3 (AWE), and I gapped them to .028". I was thinking of trying to gap them to .032 to see if it clears, but if not, I am switching to the stock plugs.
    Mar 08 2007
    Mr. Worl-Wye
    Re: Plugs
    I went with the "side fires" so we'll see if the hype holds true... I'll report back soon.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Feb 14 2006
    Re: Plugs
    yup... takes about 20 min, no biggie
    2000 B5 S4 Stg II+
    Veteran Member Three Rings lsc2g's Avatar
    Jan 07 2006
    S3%2C%20Q8
    Calgary, Alberta, CANADA
    Re: Plugs
    i just swapped in some bkr6e's on my stage2 as my plugs haven't been changed in like almost 4 years!! yes i'm bad lol
    anyways car is much smoother, noticeably faster now and took like 40 minutes for DIY changover..
    www.eurodrivers.ca
    Calgary Canada Euro Club
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    Re: Plugs
    So finished my first tank of gas after plug change...
    20mpg 90% city. Pretty crappy. I think I need to change the gap on it. right now is at .030 on a completely stock S4. Any recommendation on gapping?
    Dec 06 2007
    Calgary, AB, Canada
    Re: Plugs
    0.026
    Sep 27 2007
    Columbia, SC
    Re: Plugs
    Doh!
