Results 1 to 40 of 40
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    AC glove box mod brought back from the dead
    Parts needed:
    Part number: 8E1816311 AIR HOSE
    Price: $8.00 Quantity: 1
    Part number: 8E08207014PK AIR OUTLET
    Price: $23.51 Quantity: 1
    All available at www.VWParts.com
    Tools needed:
    8mm socket with a minimum 9" extension arm
    Hammer
    Flat Head Screwdriver
    Begin with taking the glove box out. There are 9 screws.
    7 are located inside the glove box and are easily located. The last two are located under the glove box on the extreme left and right sides of the passenger footwell area. It's highly recommended that you use an extension arm for your socket driver when trying to reach the two screws in the back of the glove box. They are nearly impossible to get out without an extension.
    Removing the top screws.
    Next you should disconnect the power harness to the glove box light.
    You should see the plug for the A/C duct near the back of the center console. Just give it a tug and pull the rubber plug out.
    Now install the glove box air duct by lining up the keyed end of the pipe with the hole. Once it's lined up you will need to give it a counter clockwise turn, about a 1/4 turn. The duct should feel nice and snug with no movement at all when touched.
    Next you will need to tear the insulation along the perforations. It's obvious the area that needs to be removed. Just pull easily while holding back the rest of the insulation with your other hand so that you don't rip the entire insulation from it's connection to the back of the glove box.
    The next step is to remove the temporary hole cover in the back of the glove box.
    Punch out the hole using the flat head screw driver and the hammer. Just line the flat head screw driver up over the small pieces of plastic that is holding the hole cover onto the rest of the assembly. There are four locations. You will want to prevent damaging the glove box by not hitting the screw driver too hard. A small tap should do the trick.
    Now all that's left is to re-install the gove box. If done correctly, the air duct you installed should line up perfectly with the glovebox hole. It's best if you support the bottom of the glove box with something so you can use both hands to turn the socket screws.
    Next screw the valve cover onto the pipe and your're done
    *Pics are no longer available from need4sleep who originally wrote this procedure. I just cleaned it up a bit to read a little better. An email is in to him to see if he still has them available. I did this mod years ago. I would go take my own pics but that would require me to take out my glove box which I am not going to do for you right now This was also posted on AZ years ago but was lost through one of the transitions.
    CAUTION: A tray might want to be kept inside the glove box so condensation from beverage bottles doesn't soak the material in the glove box. I have never had to do this as I'm not usually over using it to that point.
    Feb 12 2004
    Everywhere
    Re: AC glove box mod brought back from the dead
    Just a little info for those who care....
    Took my trip to Cali and have never really used the ac glovebox mod before (had it since 2004)....well that is over now. I can't believe how cold a damn coke was after 10 hours of driving. Thought I just took it out of the fridge or something lol. I was very impressed, especially since this was about the cheapest mod I have done on the car to date.
    Jun 08 2008
    Calgary AB Canada
    Feb 12 2004
    Everywhere
    Quote Originally Posted by onceover View Post
    NICE you found them!!! I was looking at his B6 forum post and not the tech section.
    MUCH appreciated
    Jun 08 2008
    Calgary AB Canada
    glad i could help
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    ...Or you can get one of those coolers that plug in to the 12V socket in the trunk...$14.99 at Target...you can take that out when you don't need it.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    This probably sounds retarded but I took out my glove box the other day to re-route my iPod cable from my D3 (and to see how tough this mod might be for someone as DIYtarded as myself), and I had the hardest time getting it back on. I got all of the screws in except for the top 3 closest to you. I put them in, they spin, but never catch. Anyone have any idea what I'm talking about or should I stop trying to do crap myself?
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    ha, awesome. I was telling someone about this mod just yesterday morning.
    Dec 06 2007
    those parts aren't available at VWparts anymore, that website doesn't exist i don't think, anyways the dealer wanted $40 for each part.
    -Kirk
    BetaAlphaTau Member #58
    Feb 12 2004
    Everywhere
    Quote Originally Posted by Exanimas View Post
    Are you pushing in the glove box at the same time while trying to get them to catch? Take a flashlight to the hole and see if the backing tab the bolt screws into is in the right place...
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Quote Originally Posted by AudiA4Turbo22 View Post
    Anyone have a source for the parts other than the dealer?
    Also, any suggestions for which tray to use to avoid condensation & mold?
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Feb 12 2004
    Everywhere
    I'm sure you can find any kind of tray you want and throw it in there be it something at walmart or whatever works. Shoot, even tupperwear should work with using velcro on the bottom. I'm sure you can find something more eye appealing though. I didn't have any issues with a wet glovebox on my trip.
    Dec 06 2007
    -Kirk
    Mar 09 2008
    is full of crap.
    Boston, MA
    Quote Originally Posted by CO AVANT View Post
    Will do. Thanks for the suggestion.
    -Nick
    Dec 19 2007
    York, PA
    those arent direct links...this may be:
    http://www.genuinevwaudiparts.com/pa...14407&items=10
    nope..that doesnt work neither. just search for the parts...ones 29.82 & the other 11.35
    Dec 06 2007
    ^^thanx for telling me. it was $11 and $31 for the parts.
    -Kirk
    Registered Member Two Rings zims666's Avatar
    Apr 17 2008
    '05 A4 B6 1.8t 6speed
    Chapel Hill, NC
    Quote Originally Posted by 04QuattroTurbo View Post
    x2
    ac glove box =
    time & money that could be better spent on a joeymod or any other functional mod
    Feb 12 2004
    Everywhere
    What's not functional about it? Truely the "joey mod" is not "functional" lol. Sorry, $40 doesn't kill my wallet. If it did, I wouldn't own this nice of a car. Took me all of 30 minutes to do this mod. My car is my hobby so no time wasted for me ;)
    Dec 06 2007
    ^^AGREED.
    -Kirk
    Veteran Member Three Rings fritzner's Avatar
    Nov 30 2006
    05 Red USP Avant 1.8T 6spd
    Pittsburgh, PA
    i did this about 2.5 yrs ago and love it.. i originally did it on my '02 Sedan when i was doing my RNS-E / DVD player.. but now the RNS-E / DVD player and cool box are now swapped into the '05 USP Avant!
    i havent had any trouble with mold or condensation, but i usually close it when not in use.. sure i dont use it every day, but its a cheap mod that works really well on road trips..
    i got my parts from Mike Potter at www.parts4vws.com.. they are not on the website, but i just called him and gave him the part number..
    i was really bummed to find out it was not an option in my newly acquired C5 A6 Avant..
    CO AVANT for bringing it back..
    >'05 Brilliant Red A4 USP Avant 1.8T 6spd
    ...REVO-II | TT injectors | RS4 sway | RS4 Pedals | podi
    ...Moven SP-10 (sportec reps) | 3.0L brakes | RNS-E | coolbox
    ...USP CLUB MEMBER #118
    Dec 06 2007
    ^^u comin tomorrow to the meet?
    -Kirk
    Feb 12 2004
    Everywhere
    oh and I forgot to add that this is a must if you are running an external dvd player in the glove box like I am with the rns-e. Keeps that thing from overheating in such an enclosed area.
    Nov 30 2006
    Pittsburgh, PA
    if you're talking to me, unfortunately no i cant make it.. hopefully i'll make one soon..
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by WiZZLa View Post
    I still have a bunch of these at home somewhere. I will ask Tracee to look for them, I think they are in a tote with a bunch of misc. parts I brought back from Germany.
    I'll reply tomorrow if she is able to find them. At on time I had 30 and I think I sold less than 20 of them.
    Dec 06 2007
    ^^i'll Take A Set.
    -Kirk
    Jun 13 2008
    Bay Area
    Quote Originally Posted by 400HPA4 View Post
    if you let me know how much i might be interested!
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I am not really trying to sell parts on here, If I find them I will send them to you guys for the postage cost.
    Do not PM me or call dibs, give me a chance to let Tracee dig for them, she works at her own pace.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Greg, I'd like a set too.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jun 13 2008
    Bay Area
    thanks Greg, please let me know!!!
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Why not? I'll buy one too. No rush
    -Sami-
    Mar 21 2006
    Lakeland, FL.
    Nothing is better then a chilled box!
    I'm back bitches!
    Veteran Member Three Rings sadpandas's Avatar
    Oct 05 2006
    b6 a4 grocery warrior
    High Atop The Eagle Rock
    Quote Originally Posted by dirtybrd View Post
    actually a steaming and sloppy box is waaaaaay better.
    love,
    pandas
    i do it for the people!
    b6 a4 avant-blk/blk
    2010 Kenny Anderson 'Bar' series, Royal O.G. trucks, 54mm Girl Streamline wheels
    Dec 19 2007
    York, PA
    np mang
    Jun 30 2007
    Raleigh, NC
    greg with the hookup!
    fridge in the glove-box ftw.
    i wonder if it can keep things warm in the winter? lol
    it'd be nice to have a nice warm pair of gloves when i get out of the car at the mountain.
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    Quote Originally Posted by B6Lovin View Post
    Dont see why it wouldnt. I want to figure out how to make my seats have a\c put in them. My pops lexus has air conditioned seats and they are sweet..Ur ass actually gets cold...Very nice
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by sadpandas View Post
    love,
    pandas
    More like a warm, moist, tight box
    EDIT: I'll take a set of the parts needed to do this mod from Greg.
    -Doug
    Jun 05 2008
    Minneapolis MN
    What an awesome mod! I geek out on little stuff like this I can't wait to do it.
    Thanks to all who posted useful information.
    Nov 30 2006
    Pittsburgh, PA
    when i 1st installed this a few years ago, i messed around with it and it seems to be before the heat exchanger..
    with the AC on, i cranked it all the way to 85*.. the air blowing out the vents was hot, but the air coming in the box was cold..
    if the AC is off (or ECON on) it seems to be ~outside air temp..
    give it a try, i could be wrong, but i dont think it works as a mitten toaster..
    Jun 30 2007
    Raleigh, NC
    ^lame, that's the kind of catch i was expecting. oh well, its still cool to have a fridge in our cars lol
    The Awesome™
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    In like sin.................
