Results 1 to 11 of 11
Thread: GIAC chip
    Mar 17 2008
    PA
    GIAC chip
    I have a GIAC chip that came out of a 2005 A4 1.8t quattro....$300
    Veteran Member Four Rings mister_tu's Avatar
    Sep 27 2007
    Boston, MA
    Re: GIAC chip
    Interested...PM.
    Mar 17 2008
    PA
    Re: GIAC chip
    bump
    Veteran Member Four Rings golgo13's Avatar
    Apr 29 2007
    Tampa Bay
    Re: GIAC chip
    IF my ecu is damaged and i find out I need another stock chip i will be very interested. I will let you know later on tonight or monday. if you can hold it for me that would be great .
    will it work for a 2003 fwd a4?
    GL with sale.
    SweetnLou!
    Active Member Two Rings RTM's Avatar
    Aug 18 2007
    Plymouth, Michigan
    Re: GIAC chip
    will this work on a 04 A4 1.8t Quattro Tip? if so is it easy to install? what type of increases does it provide?
    Mar 17 2008
    PA
    Re: GIAC chip
    Quote Originally Posted by RTM View Post
    i dont think it would work for a Tip....its for manual. GIAC claims a 30-38 hp increase.
    Sep 27 2007
    Boston, MA
    Re: GIAC chip
    Quote Originally Posted by jjg33r View Post
    On the GIAC website, and every other website I've looked it doesn't specify a difference between a tip and manual. Maybe someone should find out?
    Mar 17 2008
    PA
    Re: GIAC chip
    Quote Originally Posted by mister_tu View Post
    i found this:
    http://www.giacusa.com/programs.php?mpid=224
    this is different software than manual, correct?
    Mar 17 2008
    PA
    Re: GIAC chip
    buuuuuump
    Mar 17 2008
    PA
    Re: GIAC chip
    i believe it will only work for a manual....you should take it to a shop for install. about a 30hp increase.
    Mar 17 2008
    PA
    Re: GIAC chip
    ttt
