Results 1 to 27 of 27
    Veteran Member Four Rings Frey7190's Avatar
    Feb 27 2008
    is fulla audi parts!
    Seafoamin the 3.0 Were do I put it in?
    So I have decided for my 65k service I will seafoam it, in hopes of cleaning it out a bit.. My question is were (which hose) do I tap into so I can stick the seafoam in?? I saw the 1.8t had a nifty little hose ppl go through, but my 3.0 doesn't have that pipe, so what do us 3.0'ers put the seafoam in?
    Thanks
    Here a pic of the engine:
    - 2016 VW MK7 GTI Performance Pkg. DSG/Nav/Light pkg/cloth seats.
    - SOLD 2012 Audi TT 2.0T DSG Quattro RNS-E, S-Tronic, Volcano Red, 35% Tint, HID Fogs
    - SOLD 2005 BMW E46 330ci 6mt, K&N intake, //M3 strut brace, SS brake lines, ccfl angel eyes, Stoptech brakes... and more!
    - SOLD 2004 Audi A4 3.0LSport, Automatic CVT, RS4 Sway, Drilled and Slotted Brakes, SS brake lines, RNS-E, E-Codes, Hi-Flo Resonator, Tint 35%, S4 spoiler, HID Fogs, APR Snuby
    Feb 27 2008
    Re: Seafoamin the 3.0 Were do I put it in?
    BUMP!! Hello!! I need an answer Im doing this in an hour or two!
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Don't you just put it in the crankcase for oil? If you are cleaning the engines. Here, I hope this helps:
    SEA FOAM MOTOR TREATMENT for Gas Engine Applications
    100% Pure Petroleum
    Use in All Engines in All Seasons
    2 Cycle, 4 Cycle, and Diesels
    Treats 3 Critical Areas: Gas Tank, Fuel Systems, and Crankcase
    * Cleans fuel injectors
    * Cleans carburetor jets
    * Cleans carbon
    * Stabilizes fuels
    * Upper cylinder lube
    * Removes moisture in fuel
    * De-icer
    * Frees sticky lifters
    * Frees sticky rings
    * Removes moisture in oil
    * Cleans P.C.V. systems
    * Cleans catalytic converter odors
    * Oxygen sensor safe
    How Many Mechanics Use SEA FOAM
    In Tune-Up of 4 Cycle Gasoline Carbureted or Fuel Injected Engines
    Autos, Trucks, and Tractors
    1. With engine warm, slowly pour 1/3 to 1/2 pint through carburetor or throttle body throat. (If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or brake booster line.) This will pull SEA FOAM down on top of the pistons and to the back of the intake valves to dissolve carbon. Turn ignition off. Restart engine after 5 minutes. If severe carbon build up is apparent, use more Sea Foam as previously directed. Make sure exhaust is well ventilated when using Sea Foam in these various ways as fumes will be extreme for a short time.
    2. Pour 1/3 to 1/2 pint into oil crank case to clean rings, lifters, dirty parts and remove moisture.
    3. Pour 1/3 to 1 full pint into fuel tank to clean injectors, carburetor jets, fuel lines and remove moisture.
    4. Immediate Results: Smoother idle, increased R.P.M.'s better throttle response and improved performance. See label on can for detailed results for use in each area.
    FUEL TANK, CARBURETOR, INJECTION and OIL CRANKCASE.
    For Peak Performance, Use SEA FOAM Every 2,000 to 5,000 Miles
    * A 100% pure petroleum product for use in all gasoline and diesel type engines, both 2 and 4 cycle. OXYGEN SENSOR SAFE.
    * Cleans dirty engine parts internally by removing harmful gums, varnish and carbon. WORKS AND PERFORMS INSTANTLY.
    * Removes moisture from oil crankcases and fuel tanks.
    * Stabilizes and conditions fuels. Use for engine storage.
    * Cure hesitations, stalls, pings and rough idle due to carbon buildup.
    * Helps pass emissions test. EPA Registered.
    When Used Thru Injection or Carburetor
    * Cleans carbon build up
    * Cleans intake valves and pistons
    * Gives smoother idle
    * Cures hesitations and pings
    * Restores power and pickup
    * With warm engine running, SLOWLY pour 1/2 pint through carburator, throttle body or direct manifold vacuum line that will feed ALL CYLINDERS. Possible sources are P.C.V. valve or brake booster line. Turn ignition off. Restart engine after 5 minutes. Be sure exhaust is well ventilated. Fumes will be extreme for a short period of time.
    * For use in injector cleaning machines, use 50% SEA FOAM and 50% fuel.
    * Fill diesel filters with SEA FOAM to clean injectors fast.
    When Added to Crankcase (Oil)
    1. Frees sticky lifters and rings
    2. Increases R.P.M.'s vacuum and compression
    3. Cleans dirty parts
    4. Removes moisture
    5. Cleans PCV valve systems
    One pint treats 10 quarts of oil (avg. 1 1/2 ounce per quart).
    When Added to Fuel Tank
    * Cleans fuel injectors and carburetor jets
    * Cleans carbon as you drive
    * Lubricates upper cylinders
    * De-ices and removes moisture
    * Diesel full conditioner and anti gel
    * Stabilizes fuel
    One pint treats 8-25 gallons of fuel (average 1 ounce per gallon).
    In Injector Cleaning Machines
    Add a 50/50 blend of fuel and SEA FOAM into injector cleaning machine. Run directly through the fuel rails to clean injectors fast. Add SEA FOAM to your fuel tank to clean injectors as you drive.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Feb 27 2008
    Ya were is this line?
    Veteran Member Three Rings Ultra B6's Avatar
    Sep 05 2007
    New Jersey
    ive been trying to figure out the same thing for some time now with no luck.. hopefully someone can answer it !!
    -James-
    04 Dolphin A4 USP CLUB MEMBER #84 3.0 QUATTRO TIP
    MODS:
    Pics:http://s231.photobucket.com/albums/ee167/ultrab6/
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    I believe the vacuum line you are looking for is under the front-most engine cover. I'm not 100% sure since my vac system looks nothing like stock anymore. Search over on AW for which vac line the 2.8 guys use when seafoaming.
    Tyler might also know. I think he did this recently.
    Sep 23 2006
    Houston TX
    yeah, I'm not exactly sure which line is which on stock. Take more pics of your engine with the engine covers off (near front and also over TB). If I get a chance I'll try to look up some diagrams.
    Established Member Two Rings tj19855's Avatar
    Jun 30 2008
    2003 Audi A4 Quattro 3.0 (B6)
    Houston, TX
    :) hold on
    Jun 30 2008
    Houston, TX
    Here you go..
    Jun 15 2008
    Fairfield, CA
    ^ Ftw!
    USP Member 110
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    Only 50-100 miles in the crankcase???
    I recommend AutoRx for the crankcase. Worked great for me.
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Buncha motorcycles
    Memphis, TN
    its never good when a man has to ask "where do i put it in?"
    APR Stage 2/AWE Intake
    Deactivated Three Rings
    Apr 11 2008
    OMG! This is f*ckin gold.. I was looking for this all day..
    Apr 04 2007
    PHX, AZ
    Quote Originally Posted by tj19855 View Post
    Here you go..
    What is the order to all of this? Obviously put 1/4 in for the crank case 50-100 miles before my next oil change, but what about putting it in the gas tank and in the other hose pictured on top..Do I do it all at the same time, or do I wait after the 50-100 miles then do the rest(gas tank, other hose) before I change my oil?
    Paul Cordero
    [email protected]
    Registered Member Two Rings
    Aug 05 2008
    Philly
    put about 1/3 in the oil. then run it for a day or 2. then change oil. you might wanna do this right before you need your oil changed. I have yet to do the PCV valve/vaccum line, but i would assume that there will be a hose coming off one of the valve covers feeding into the throttle body. again, i just bought my 3.0 so i haven't really snooped around yet. as far as the gas tank, i usually put in about 1/3 in there as well. with the whole can you should be able to do all 3. HTH
    Registered Member Two Rings I Audi5K I's Avatar
    Jun 15 2007
    2002 A4 1.8T QM
    Atlanta
    thats what she said
    2002 A4TQM
    Forge 007 DV
    Coming Soon:
    | Revo Stage 1 | RNS-E | Racetec FMIC | Milltek Exhaust |
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    Can we get some more pics of the line we fill with 100% petroleum...aka seafoam??
    Feb 22 2008
    San Diego
    Here you go..
    Aww man. Does anyone have this pic anymore? It's not available anymore and there it apparently was the keystone in this discussion.
    Veteran Member Four Rings nein-reis's Avatar
    Feb 01 2008
    MK6 GTI, MK1 GTI 1.8T, B7 A4 TE Avant
    SLC, Utah
    Yeah... I would like to know also!
    -Tyler-
    Built 06A/IE Cams/IE 2.0 stroker/GT3076/6MTQ
    Dan Shank Super Tuned
    It was a fun run, but the time has gone.
    Established Member Two Rings nezach's Avatar
    Nov 03 2007
    02 A4 3.0 Quattro 6spd
    Chicago, IL
    This is where i put it.
    Auto cars will also have brake booster connecting there.
    Sep 07 2007
    Atlanta GA
    alright thanks guys
    Senior Member Two Rings jdogg's Avatar
    May 19 2009
    All over her chest!
    Oops wrong post...
    Feb 27 2008
    So does that brake booster line get the entire crankcase wet with sea foam?? Cuz on my explorer (v6 4.0) it only would get sucked into the three of the six chambers.. leaving me with three dirty ones and three clean ones lol... I guy on the BMW forms told me that when I used it on my 04 330Ci to remove the sparkplugs and put a little (1/2 a tablespoon or so) into each of the spark plug holes... I did that and then turned that bimmer over and I got the smoke show, and hopefully a clean engine lol...
    Jul 16 2012
    PA
    Quote Originally Posted by nezach View Post
    hey sorry for the necro, and this is probably a stupid question, but do I just cut off that clamp on there and replace with a regular hose clamp after seafoamin my car?
    Jul 04 2012
    Audi A4 3.0 6MT Mazda Rx-7
    Queens, NY
    Any updates on how this came out? Want to do it to my 03 3.0 and at 191k it might make it run a bit better.
    This doesn't harm the 02 sensors or anything else right?
    Jul 16 2012
    PA
    Quote Originally Posted by NYsNumba1man View Post
    I did mine last night and took it for a spin, ok so far. I got the smoke but not as much as the ones I've seen on youtube. I also didn't use the hose on the pic on this thread. I used this one instead:
    http://forums.audiworld.com/showpost...59&postcount=6
    I didn't drive it to work today though since the PS fluid is low. I'll grab some fluid after work, fill it up, and drive it to work tomorrow.
    Apr 07 2011
    For a gas treatment pick up a can of BG44K from a dealership for $20. It's the best $20 I've spent on my car. They also have an oil treatment but I haven't used it. I did put half a can of seafoam in the oil and ran the car for about 20 minutes before changing the oil.
