Results 1 to 4 of 4
    Dec 27 2005
    New Orleans
    any experience with KMAC or Camber Kits?
    Here's the story..I bought new tires(kumho ecsta) around 35k miles after noticing that it was balding on the inner sides due to neg camber. So I got an alignment and thought it was fine and dandy. So my 45k checkup comes around and the tech shows me that my tires are all balding in certain spots again!
    So the tires only lasted me around 10k, and im looking to see if anyone has any experience with the kmac camber kits on the b7 model. I might as well grab a set of rims with tires and the camber kit instead of just buying another set of tires.
    BTW i also read from a previous thread that its from off toe angle, and not really camber. If so, does that mean I can fix the tire wear without buying the camber kit?
    Established Member Two Rings tileg's Avatar
    May 01 2008
    Philadelphia
    Re: any experience with KMAC or Camber Kits?
    i was told to rotate every 5k
    Veteran Member Four Rings DoThisMyWay's Avatar
    Aug 24 2004
    B9Q5
    Honolulu, HI
    Try and set toe as close to zero as possible. Where are the tires balding now?
    Current:
    2024|A5 SB PP+ S-line, 2019|Q5
    Previous:
    2017|S3, 2016|A4 2.0T Quattro, 2006|A4 Avant 2.0T Quattro S-line, 2005|A4 3.0 Quattro UltraSport
    Dec 27 2005
    New Orleans
    i just rotated today and the front tire had the wires showing already on the inner side. I had to bring out the spare wheel..and probably will order some new tires/wheels soon. I should have rotated every 5k..now i know for next time
