just wondering if the crank/ rpm sensor needs to be adapted by VAG COM?
B7 S4 Avant
2001.5 Audi S4 stg 3
K04s, 85mm MAF, 60lb injectors, custom software
ASP DTS/Tru-Dual/Downpipes
Stasis Tracksports/4:1 Centre Diff
Neuspeed 19mm rear sway - CPP rear end links/tie rod ends/front upper control arms
VAST ceramic clutch, RS4 pressure plate, JHM shifter
RS4 engine/trans mounts, Stern rear diff/snub mounts 55 watt HIDs, Odyssey PC680 battery, Innovate Wideband
