Results 1 to 20 of 20
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    16815: Warm up catalyst bank 2, eff below threshold (sporadic)
    I googled and searched. Came up with these 3 results.
    1. Exhaust leak
    2. Bad catalyct converter
    3. Bad O2 sensors
    * How do I know which of the three is bad?
    * If bad O2, how do I know which of the O2 sensors do I replace? Theres like 3 isnt there?
    * If exhaust leak, how do I fix? (New exhaust system?)
    * If bad CC, how do I fix? (Again, new exhaust system?)
    2015 B8 SQ5
    Click Here
    Past
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: 16815: Warm up catalyst bank 2, eff below threshold (sporadic)
    1. Exhaust leak
    3. Bad O2 sensors
    Bank 2 is driver side. Mine was fixed by changing the primary(upstream) sensor, even though the rears(secondary) generate the actual code, they take a reading from the two. You need a VAG-COM to log them and see which ones are out of spec.
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by mholme View Post
    I bought that VAG-TOOL/PALM thing through JayC on here. I utilized that to figure out the code...
    but like you said, Bank 2 is driver side, meaning that I should replace the front O2 sensor on my side, yes?
    2015 B8 SQ5
    Click Here
    Past
    Jan 29 2007
    08 S4 00 S4
    MD
    You still need to log the sensors. One of them may be out of spec causing the code to be thrown. In my case, it was the primary that was at fault. Your mileage may vary..
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Yeah it's def your diver's 02's like mholme said logg your o2's and see what's going on. I have this code come up every once in awhile , but thats apparently due to the GIAC chip i have that is coded for cat delete? who knows if thats true thats just what I was told.
    2010 Brilliant Black/Magma Red S4
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Subscribed because I've had a CEL for this code for a while. I've heard it was O2 sensors or cats. Most likely O2s though.
    Jun 14 2007
    2000 S4
    Connecticut
    i had this code, below threshold, but thats because i have straight pipes with no cats LOL.
    Oct 31 2005
    Ashburn
    I've had this code for awhile. it was my front driver side o2. It also caused the car to throw a bunch of other codes.
    Monday,19,May,2008,10:22:49:58049
    VAG-COM Version: Release 704.1
    Address 01: Engine
    Control Module Part Number: 8D0 907 551 M
    Component and/or Version: 2.7l V6/5VT G01 0002
    Software Coding: 06711
    Work Shop Code: WSC 88811
    5 Faults Found:
    17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
    P1113 - 35-10 - - - Intermittent
    16815 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
    P0431 - 35-00 - -
    17965 - Charge Pressure Control: Positive Deviation
    P1557 - 35-10 - - - Intermittent
    16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
    P0421 - 35-00 - -
    18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
    P1650 - 35-00 - -
    Readiness: 0000 0000
    The other o2 sensors were good. once i replaced the primary o2 no more codes.
    - Instagram: @Sinister_rs5-
    Apr 17 2007
    B8 A5
    Same...does this mean I need to disable the code from being thrown?
    Oct 31 2005
    Ashburn
    Quote Originally Posted by tike0rz View Post
    Do you have defoulers?
    when i did run test pipes i had the vast defoulers and never had a problem. my only issue was emissions so know i have highflow cats.
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    I have the same issue...had did you resolve it? I bought the vast celeliminators...couldn't really get them to fit, but was told you can trim them down?
    Veteran Member Four Rings casawhites4's Avatar
    Jan 21 2007
    01.5 Silver Avant
    dc
    i got the vast celimnators...and they worked just perfect...had induktion trim them down some and boom i was perfect...just go that route for now.
    01.5 Stage 3 Casablanca White S4 (GONE)
    01.5 Stage 0 Silver S4 Avant (New Project, def Grocery Getter)
    watch out Casablanca!!! im coming back with a vengeance!
    Silver will be the fastest now!!! :-D
    Dec 02 2007
    DC/MD/(VA)
    Noted.
    Crash course on how to log the sensors?
    My VAG-TOOL program has a program that logs something, is that what you gents are talking about? I guess I'll "log" them and post them...
    2015 B8 SQ5
    Click Here
    Past
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Noted.
    Agreed, Know how to log them, but what values will be "in spec" and what wont?
    Senior Member Two Rings Jayco88's Avatar
    Jun 02 2008
    2000 S4
    I had the same issue. I wasn't sure if it was the cat or o2 sensors. But then I did piggies and flashed my ecu with the APR stage II (which supposedly ignores rear o2's) and my problems were gone. I guess my rear o2 sensor was a little goofy.
    -It's got nothing to do with your vorsprung durch technic, you now.-
    May 23 2008
    Columbia, SC
    I have GIAC stage 3 programming, but I want the o2's coded out...so what are my options and how much? Do I have to ship the ecu off or can I just find a local shop?
    May 23 2008
    Columbia, SC
    no luck with the vast celeliminators...couldn't get them to fit. Couldn't I just use spark plug de foulers? If I want to get it coded out in the ecu how would I do that?
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by Allaidback View Post
    Yes you can. I'm running non-foulers on piggies. I thought APR stage 2+ code was the only software that eliminated the rear O2 readings.
    Senior Member Three Rings S4shpion's Avatar
    Jul 04 2007
    New- 23 RS3 | Old -01 S4
    Chicago
    Vast can code out the o2 readings. Contact The_Jerbel (distrubuter of Vast) and he can hook you up. I have the same problems codes were there before i got piggies and they still there after. I didnt use the celiminators, i was just going to get a semi custom tune from The_Jerbel with the o2's coded out as well as my SAP system.
    2023 Python Yellow RS3
    Tech, Sports Exhaust, Carbon Fiber Package, Black Optics, 30% tint, IGL Kenzo ceramic coated.
    Sold
    2001 Brilliant Black StageII+ TIP S4 ..
    Giac-X, Piggie Downpipes, Vibrant Exhaust, Koni|Vogt shocks|springs, 710ns, Samco TBB, SPP dimpled|slotted black zinc rotors | Hawks HPS street pads, 35% tint all around, 18"s OZ Ultraleggaras.
    Established Member Two Rings blister83's Avatar
    Feb 27 2008
    Charlotte, NC
    How do you log the sensors with the VAG-COM cable?
