Results 1 to 9 of 9
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Lemmiwinks and Unisetting
    I have both downloaded to my computer but for some reason lemmi won't work and unisettings works but then for some reason when I go to change settings it pops up and says ecu cannot be read. Its is weird since on my first try everything worked then after a run it would not. Then while I was at a gas station on like the 20th try it read the ecu again. However when it was working on me I added 1.5 degrees of timing, not that much but the car is already starting to pull harder, and the boost is coming on sooner. I need to figure out this software since I logged the car and Im still not seeing an CF's. Anyone have any ideas? TIA.
    Some fast things and some slow things
    ~Josh~
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Re: Lemmiwinks and Unisetting
    make sure you have it on the right com port when you open up lemmi or uni. You may have it on 1 and then have the usb in the wrong usb that isnt 1 for example
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Oct 31 2005
    Virginia
    I see, I'll have to check that out
    ~Josh~
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Lemmiwinks does not work with my vag com cable, might for some but not me. Had to use a single serial pc card and obdtool to get it to work for me. Make sure the com port settings match up. Just try each one in lemmiwinks.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I have to mess around with that tonight.
    I recall old guy posted a link once that contained a document of all the blocks within the engine controller. Do you know where that document resides? I want to see what else is available for logging purposes.
    -Doug
    Feb 27 2005
    North Wales, PA
    anyone got a walk through on how to set up unisetting? i can't get it to work with an ebay cable. I use the same port as my vag-com and no luck.
    Feb 12 2004
    Everywhere
    Shoot unitronics a call. I tried forever to get it to work but couldn't. They kept revising and revising the software for it. Worked fine on all the VW's but not the audi's when I was messing with it last year...
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    From what I understand these programs will not work with a USB cable, I could never get my lemmiwinks to work with my USB Vagcom which is why I kept my old serial vagcom cable when I bought the USB version. Also if you have already made changes you must read the settings from the ecu before you make any changes to the values and then reflash it.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Found it: http://www.ross-tech.com/vag-com/m_blocks/
    -Doug
