Results 1 to 9 of 9
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    *** Introductory - B7 Density Line Motor Mounts ***
    Well guys you asked for it and its here:
    New 034 Motorsport density Line mounts for the Audi A4 B7
    We are VERY excited to be announcing the release of our 034Motorsport Street Density and Track Density motor mounts for a wide range of Audis!
    We've been testing these mounts for some time to ensure they are reliable and meet the criterion for the intended use - results so far are very exciting!
    WHAT THEY ARE: A new line of rubber motor mounts made FOR us by OE suppliers to OUR specifications.
    STREETDENSITY Mounts are solid rubber mounts with a 50 durometer about 10% stiffer than stock, this means they still ride smooth and quiet but provide a marked improvement in drivetrain dampening over stock mounts. Livable street performance with serious sport intentions. Note, since there are no voids or air pockets in these mounts, even though the rubber is only 10% stiffer, the resulting reduction in drivetrain movement is actually 25% stiffer.
    TRACKDENSITY Mounts are also solid rubber mounts, but with an 80 durometer approx 90% stiffer than stock, these are solid for all practical purposes and result in ZERO drivetrain movement. Vibrations from the engine are noticeably increased but not horrible. Definitely not smooth and quiet like stock mounts, but in return you get a completely locked down drivetrain with NO slop or deflection. These are perfect for the street/track enthusiast who doesn't mind a marked increase in vibration from the drivetrain.
    NOTE, THIS IS NOT AN OE MOUNT, OR AN RS4 MOUNT, AND ARE NOT AVAILABLE FROM ANY OTHER SOURCE - These are built by an OE supplier to 034Motorsport specifications.
    OE style gray rubber dust covers are included with each mount.
    PRICE = 200US shipped anywhere in the lower 48.
    Please send me a PM when you are ready to order and please specify whether you want STREET or TRACK Density Mounts.
    Nov 12 2007
    Grand Junction, CO
    Re: *** Introductory - B7 Density Line Motor Mounts ***
    Doesn't APR make a similar produce for $30?
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Quote Originally Posted by AudiWxGuy View Post
    You're thinking of the front lower engine mount (snub mount). These are the two rear engine mounts.
    Feb 26 2006
    Earth
    This is for the engine mounts,Not the snub mount.We also make a snub mount & bracket for the B6 & B7's
    Nov 12 2007
    Grand Junction, CO
    oh, okay.
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    $200 for both or one?
    The usual things!!
    Resistor Install
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    How bad is the install?
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Feb 26 2006
    Earth
    $200 for both (left and right).If you have the skills the install time should be minimal.
    Feb 26 2006
    Earth
    All PM's replied to.
