The black wire is the 12v source going to the relay. We installed 2 wiretaps on that black wire and sent them to the hot/cold leads on the switch. Once we had good connections all around, we cut the black 12v wire between the wire taps. The switch is consealed on the lower portion of the kick panel.
It's a bit tight back there, but take your time and make sure you free up enough slack in that wire before cutting into anything.
We also attempted to modify the relay -- to avoid hacking into wiring, but the relay is really an electronic module, so that wouldn't work.
Sorry I didn't take any pics, but here are reference threads:
http://www.audiworld.com/tech/elec35.shtml
This one has pics -- ignore the parts related to the shifter. He wanted the serviotronic off while in TIP mode, so there is alot of extra stuff you don't need.
http://home.earthlink.net/~oxy8384/605mod.htm
