Results 1 to 4 of 4
    Jun 11 2008
    Williamsport, Pa
    air conditioner quit working
    Well my ac is still moving ice cold freon but it no longer blows. the freon pipes i hear the hissing and can watch the ice form on them. When i put the heat on high hot air comes out but not blown just as its coming out because that's the path of least resistance.
    is there just 1 blower that controls heat/ac or are they separate?
    this summer is a bit warm/humid to be driving around without ac.
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    Re: air conditioner quit working
    your refrigerant charge is low, evaporator hissing is a good indication of low charge, i understand the pipes are getting cold, but if you are getting ice on them it is too low causing the pressure on the low side to go way low causing freeze up which results in no worky of the ac.
    Jun 11 2008
    Williamsport, Pa
    so basically recharge then reevaluate. but even if it was low wouldn't that mean that some sort of air would be pushed or is it low refrigerant no worky.
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    I had an ac leak in my car. Wound up being a bad O ring. replaced, re charged, now I get this hissing noise from the passengers side dash/floorboard area when I have the heat on. WTF is it?! Is it related to the ac charge? Last winter is when I lost my refrigerant, I drove the car through the winter and the heat was fine. no Hissing. this summer I bought a bottle of the refigerant, used almost the entire thing (was a big bottle) and this winter I noticed that i have a hissing sound when the heat/defrost is running. Any ideas?
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
