    Senior Member Three Rings auto_euroticaA4's Avatar
    Jan 30 2007
    00' audi a4 1.8tqm,RIP boravr6
    central jersey
    cold start problem
    my car has always had a high idle from a cold start but recently its been misfiring. i turn the car on, it missed for 30-60 seconds then runs fine. one of the guys i work with mentioned that he worked on someones jetta 1.8t with the same problem and said he replaced the cold start valve. anyone have any other ideas? i'm somewhat mechanically inclined but am not to familiar with our motors.
    any input would be appreciated.
    thanks carlos
    ...cancer cures smoking...
    mk4 jetta vr6__totalled
    b5 a4 1.8tqms__totalled
    e30 325is__still in one piece....for now
    Registered Member Two Rings MidwestA4's Avatar
    Oct 04 2007
    The Palm, Michigan
    Re: cold start problem
    Coolant temp sensor would be my guess.. Sounds like your car is hot mapping on startup and loading fuel causing a misfire.
    Check your plugs and pop in a new sensor... see where that gets ya
    - 98.5 A4 Quattro
    Jan 30 2007
    central jersey
    thanks for the tip, ill give that a try. i get a p1127 code btw, i forget if its lean or rich mixture. could this have something to do with it?
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    When I first got my car, I needed a camshaft position sensor
    The way my mechanic explained it was, if you let it go, it'll run like shit after a cold start. So check for that
    ÖMGHI2Ü
    Photography
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    I have a similar cold start issue, after a little while now it won't even start first try (might not be related), seems to get worse the warmer it is. second try it fires up fine minus a few misfires in the first 30-60 or so seconds like the original poster has said. Once it's warm, it's fires up again perfectly without any misfires.
    i'm pretty sure the camshaft position sensor would throw a code, i'm not receiving any codes what so ever. I may just replace it anyway, but I'm in search of other possible problems before spending any money. For the record, I replaced my coolant temp sensor about 7 months ago (4-5k miles)
