Results 1 to 21 of 21
Thread: log-intake temp
    Veteran Member Three Rings A4twin's Avatar
    Jun 02 2007
    2016 SQ5 2021 VW Tiguan
    Pasadena, Tx
    log-intake temp
    did some logging today and here are the results. i think my intake temp is a little to high. outside temp 93*F. engine mods: giac k04, test pipe, apr cat back
    first run...
    second run...
    i think i need intercooler...
    2016 SQ5 APR OBD11
    Jun 30 2007
    Raleigh, NC
    Re: log-intake temp
    you need to log your timing correction as well to see just how badly the stock IC is affecting you...
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: log-intake temp
    I personally wouldn't run a K04 on a stock SMIC, but that's just me.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: log-intake temp
    in texas I wouldn't run a modified k03 on the stock SMIC. Is this in deg F? If you are only seeing 60deg C I wouldn't worry. I have seen my K04 with ecode fmic hit 80deg C at 5000ft on a 100deg day and I was still running fine pulling no timing. EGTs a bit high though. Log IAT again, EGT(034), Cf (020)
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: log-intake temp
    Quote Originally Posted by CO AVANT View Post
    Where did you get 60C?
    190F = 87C. Water boils at 100C. 190F is too hot imo.
    Appearance: OEM+
    Jun 02 2007
    Pasadena, Tx
    Re: log-intake temp
    yes it's F.
    CF is that timing correction?
    2016 SQ5 APR OBD11
    Feb 12 2004
    Everywhere
    Re: log-intake temp
    Quote Originally Posted by Tgr_Clw View Post
    I guessed, I don't know the conversion off the top of my head lol. 87 is damn hot. Hotter than I've ever seen even at 10000ft where it's the worst. Get yourself an FMIC now. I would recommend the ER sport.
    yes, cf is timing correction
    Jun 02 2007
    Pasadena, Tx
    Re: log-intake temp
    what about the smic by apikol?
    2016 SQ5 APR OBD11
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: log-intake temp
    Quote Originally Posted by A4twin View Post
    It's a nice product and it does improve the IAT's, but they'll still remain high. With the Apikol SMIC the max IAT's would've been around 150-160F. Improved, yes, but still too hot imo.
    Appearance: OEM+
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: log-intake temp
    Ouch, very very hot. The car must be running very sub-par. Here's is an example of my 3rd gear pulls with my FMIC at 90F ambient:
    Ranges from 30C (86F) to 38C (100F) - So a 14 degree IAT delta.
    Of course different car, but I am using an eBay core (CXRacing) which are readily available.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: log-intake temp
    FYI:
    Tf = (9/5)*Tc+32
    where Tc = Celsius and Tf = Fahrenheit
    -Doug
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: log-intake temp
    FYI:
    Tf = (9/5)*Tc+32
    Or you can simply use this
    http://www.wbuf.noaa.gov/tempfc.htm
    Appearance: OEM+
    Buncha motorcycles
    Memphis, TN
    Re: log-intake temp
    ive told people for a long time, with either 1+ or k04 you desperately need a FMIC... the car will feel like a different beast i know mine sure did..
    the upgraded SMIC only reduces IATs about 20-30 whereas my racetec drops them about 100 degrees
    APR Stage 2/AWE Intake
    Jun 02 2007
    Pasadena, Tx
    Re: log-intake temp
    i plan on getting a bigger turbo this coming year ER sport or competetion for intercooler?
    PS will log car again this saturday and will post results
    2016 SQ5 APR OBD11
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Re: log-intake temp
    I'd go with the ER competetion.
    Appearance: OEM+
    Feb 12 2004
    Everywhere
    Re: log-intake temp
    Yes ER Comp or custom is the only way to go if you are running a big turbo. I could not have any smaller with my setup at this elevation.
    Jun 02 2007
    Pasadena, Tx
    Re: log-intake temp
    here is a log from tonight temp 93F, left the logs in celcuis, was able to do one run
    sorry for some reason can't make it biggerr
    EGT max about 900*C = 1652*F
    IAT max about 90*C = 194*F
    last graph of timing, not sure how to read it can someone interpret
    thanks
    2016 SQ5 APR OBD11
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: log-intake temp
    thanks
    The last graph is showing how much timing is being corrected on each cylinder. Your correction factors are in a safe range.
    But damn, that SMIC sucks.
    Lots 'o Goodies
    Jun 02 2007
    Pasadena, Tx
    Re: log-intake temp
    what are normal correction factors
    2016 SQ5 APR OBD11
    Jun 02 2007
    Pasadena, Tx
    Re: log-intake temp
    can i ust the ER comp with my current k04 until i "save up" for the gtrs...?
    2016 SQ5 APR OBD11
    Feb 12 2004
    Everywhere
    Re: log-intake temp
    giac pulls a lot of timing but your iat's are crazy high, higher than I've ever seen. You'll be fine with the er comp until you go gtrs. Get it on there asap! The most optimal is to see your cf's as close to 0 in all cyl as possible. For instance: 0, 1.5, 0, 0 Log block 003 BTDC when you log CF's 020
