Results 1 to 16 of 16
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    Car pulling when braking....
    Any idea what this is about, If I am braking my car really pulls off to a side.... and I have a sound coming from the front, when slowing down from around 40mph...like a whining noise....could that be a wheel bearing?
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Re: Car pulling when braking....
    Maybe one of you calipers is not applying much pressure when breaking. Drive around hard for a lil bit and feel the wheels near the breaks and see if there the same temp...
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    /\ Exactly. but most likely the cause would a caliper sticking (rather than not applying enough pressure) But definetly, check the temp of each!
    -Sami-
    Nov 07 2006
    02 A4 1.8t
    New York
    Okay, Ill do that. What about a like whining noise when slowing down.....
    Nov 07 2006
    02 A4 1.8t
    New York
    Still pulling when braking. No idea about that as of right now.
    Now my other question is. My steering wheel shakes while driving, badly. I got an alignment done, and also all 4 wheels rebalanced, what now ?
    Veteran Member Three Rings A4p's Avatar
    Mar 06 2006
    Audi 1.8TQM6 S-line USP 2004
    Sweden
    if it is pulling while braking then it is defently your brakes that causes that.
    Is it only the steering that is shaking or do you also feel in the carbin?? if you feel the carbin also is shaking, then it is your wheels that need to be rebalanced. my advice to you go to a dealer where they only dealing with ROAD BALANCE, they will know exatly what the problem is, and will help you out.
    USP CLUB MEMBER 861
    Rev0 stage I file - 300+ bosch injector - OFE SS - APR Snub mount - Nitrogen - RS4 Swaybar - K&N air filter - **-
    Nov 07 2006
    02 A4 1.8t
    New York
    Hmm. Yeah, trying to avoid the dealer. I hate getting ripped.
    And yes it is only the steering wheel. Just spent 60 bucks having all the wheels rebalanced....
    Jul 30 2008
    2003 A4 1.8TQM5
    PA
    You might need new pads and/or rotors. If the pulling is only there when braking then it will probably be one of these things.
    Nov 09 2007
    Arlington VA
    Does the shaking start at a certain speed? Also do you hear any noises while making 90degree left or right turns?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Quote Originally Posted by gq9 View Post
    He wasn't saying go to an Audi dealer persay... but a reputable shop that does Hunter Roadforce balancing of wheels and tires. It is one of the best machines to get it right the first time. If anything you could bring it into one of those shops and have them check one front to see if it was done correctly. I also sounds like it is time for some new brakes if it is pulling and whinning while braking... good luck
    Nov 07 2006
    02 A4 1.8t
    New York
    Quote Originally Posted by offseri View Post
    No noises, and the shaking seems to be at any speed. At times I look at the wheel, and it isnt shaking though....
    Active Member Two Rings tvotvo's Avatar
    Aug 14 2008
    Audi A4 1.8T Quattro
    Greece
    Does the car only pulls when you are breaking hard at a speed of over 100km? If yes you need to change your sunspension
    Nov 07 2006
    02 A4 1.8t
    New York
    Quote Originally Posted by tvotvo View Post
    Nah just pulls with braking and even normal driving. Suspension ?
    Going to audi on weds, cause this sucks.....
    Nov 07 2006
    02 A4 1.8t
    New York
    Wheels rebalanced at audi today, they said whoever did them last were morons and each wheel was 30g off. So great, wasted money. Yay.
    Feb 10 2019
    Massachusetts
    Thread revival...did balancing the wheels cure the pulling issue? I'm having same issue. I need rear rotors which I haven't installed yet, butt I can't imagine the rear brakes affecting the car so much that's is pulling me to the right. I'm going to try bleeding system as suggested previously and rotating tires..since I'm lowered and haven't rotated tires in awhile...anyone else have this issue?
    Established Member Two Rings HeyCaden's Avatar
    Apr 17 2018
    95 Toyota Camry
    Red Deer/ Alberta/ Canada
    Quote Originally Posted by Mass6mtB8S4 View Post
    Issues I've found that can cause shakes and pulling to one side in my own cars;
    -wheel balance issue
    -Alignment
    -Ball joints gone bad
    -Tires have a bulge growing
    -Bent axle
    -Warped rotors
    -Caliper not applying enough pressure
    -Caliper applying too much pressure
    2003 RHD Audi A4 Avant
