Results 1 to 8 of 8
    Sep 14 2006
    PURCHASING HELP: 2001 vr6 Golf
    I currently own a stg 1+ B6 audi a4. There is a stage 3 vf supercharged 2001 volkswagen golf that I'm looking at purchasing with under 40k miles. I've never owned a fast car and this looked like a good deal to me. He lives 300 miles away and he said that he could have it delivered to me for a $2500 fully refundable deposit through ebay. He is selling it for $6500
    What should I look out for before purchasing this car? I'm just cautious because it seems too good to be true.
    Mods.... Engine: This motor was PAMPERED for the 5000 mi break in period, since then it has only had MOBIL 1 in it. Here are the engine mods. VF-Engineering Stage 3 supercharger system with front mount intercooler race bypass valves larger injectors and recomended Bosh spark plugs. Check out VF-Engineering.com for all the details of stage 3. All intake plumbing clamps were upgraded to Turbonetics T-Bolt clamps and Turbonetics hump hose silicone connectors High pressure fuel pump and pressure regulator VF-Engineering side motor-mount, trans side-mount, and pendulum lower engine-mount. Autotech light weight flywheel Tech-Tonics stainless 2.5" cat back exhaust system with a Borla silencer. Transmission: Quaife limited-slip differential Quaife reduced ratio 5th gear. (80mph is 3000rpm in 5th, about 600rpm below stock) Sachs heavy duty clutch and throw out bearing HPA Short throw shifter Suspension: Bilstein coil overs front and rear. (height adjustable) Neuspeed front sway bar Neuspeed adjustable rear sway bar Neuspeed front upper stress bar Autotech lower front stress-bar Yarrowsport rear upper stress-bar VW Racing polyurethane front a-arm bushings and "donut" lower front bushings I have 1 degree camber adjusters that are not installed yet and come with the car Brakes: ECS Stage V brake kit painted porsche blue Rear, Brembo drilled rotors and Power Stop autocross metallic pads with stock callipers All callipers painted red Body: HRE 540r's 18x8.5 up front with 225/40/18 Michelin PS2's HRE 540r's 18x9.5 in rear with 255/35/18 Michelin PS2's Customized Kamei grill Smoothed hood where emblem was removed Ottinger front bumper, rear bumper, side skirts, rear bumper cover, rear wing. Rear trunk blend peice Rear emblem and latch shaved (trunk operated by factory key FOB or factory in car button) Hella euro-spec black headlamp housings Hella zenon ballasts and bulbs from Germany Custom race fuel filler cap (works with regular gas pumps, does not cause engine codes) Interior: Factory options include, rain sensing wipers, heated leath er seats, power heated mirrors, power locks, power windows, monsoon stereo system with 6-disk in trunk changer, power moonroof. VW R-Line pedal set with dead pedal Momo shift knob 42nd Draft design 3-guage in dash panel VDO Vision series oil pressure, oil temp, and boost gauges K-40 invisible radar detector. 4mi front and rear with laser detection. you can add the laser jammer to this system. System costs $1000 new without the jammer and is undetectable for those states that don't allow them.
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Veteran Member Four Rings HeHateMe's Avatar
    Apr 05 2005
    lost wages, nv
    Re: PURCHASING HELP: 2001 vr6 Golf
    post this on the vortex
    <old school>
    --giacfxk03-siemensinjectors-milltekexhaust-ofestage4clutch-eibachprokit-stratmosphereshortshift--
    abracadabra homes http://www.audizine.com/gallery/data...une_06_142.jpg
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    Scam, the mods alone are worth 6X the asking price. That would also be a cheap price for a bone stock golf. Refundable. ahhahahahahhahahahahha Until u ask for the refund. People like u are why I don't feel bad for the mortgage chrisis. I mean, post pics of the car when u get. bwahahahha
    Veteran Member Four Rings itsdarrow's Avatar
    Jan 27 2006
    Nyc
    wow the wheels alone could sell for half the price of the car total scam!
    black B6 a4, 18x8.5 anthracite bbs ch, Full frame gt28rs kit, Unitronic 440 file, high on meth.
    Jan 29 2008
    My Garage: My Garage:
    los angeles
    bro, 2500 to deliver? maybe it's a salvage title.
    Jan 10 2007
    VA
    if you want to buy it, call the guy, ask for updated pics so you can be sure he has the car, and tell him you'll pick it up in person. that way if its a scam you'll find out before you ever leave your house...and then can see/inspect the car in person before buying it.
    Sep 14 2006
    Yeah it's a scam....I told him I had to see the car before I purchased the car and he said he was too busy(??) The 2500 wasn't for delivery it was supposedly an ebay deposit. Later he said he would ship it for $6000....wow what a scam.
    -Thomas
    Current: /S3
    Sep 14 2006
    Quote Originally Posted by bob12312357 View Post
    oh.....ok........ that's cool
    -Thomas
    Current: /S3
