Results 1 to 12 of 12
Thread: Fuel filter
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    Fuel filter
    Zero search hits for this in the B6 forum.
    Looking into replacing the fuel filter for general maintenance (no probs really), and I see "fuel filter with pressure regulator" available at GAP. Autozone doesn't have it for this car. Is the regulator really an integral part of the filter, or can I get the filter individually somewhere?
    Cheers,
    -Neil.
    Audios,
    -Neil.
    2004 B6 1.8T Avant Tip Quattro: Custom VEI digital vent gauges | Avus 18's | '02 sport suspension | Upgraded driver
    Who am I kidding? I'm never going to find time to mod this thing.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    -Doug
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Re: Fuel filter
    Search under the B6A4 forum only. Someone recently posted a whole "how to" here w/ pictures.
    May 31 2008
    Palm Beach, FL
    Re: Fuel filter
    The B6 search should've covered all B6 subforums, but I can try again. At this point I'm really just interested in knowing if I have to swap the filter with the regulator or if there's just a filter (w/o) regulator available. That AW thread btw is missing the pics :(
    Audios,
    -Neil.
    May 31 2008
    Palm Beach, FL
    Re: Fuel filter
    Actually, that is what I had tried, since B6 is B6A4 :) Just tried again, and now I get only this post.
    Audios,
    -Neil.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: Fuel filter
    I think the search function isn't working correctly on AZ right now. I can't search for certain keywords I know for a fact I have typed. It comes up "can't find it".
    -Doug
    May 31 2008
    Palm Beach, FL
    Re: Fuel filter
    Ahhh... that would explain a lot. But I was placing an order for oil etc, so I ordered the fuel filter with the regulator anyway. They (GAP) said that's the only way they know that it to be available.
    Thanks,
    -Neil.
    Audios,
    -Neil.
    Jan 24 2006
    orlando
    Re: Fuel filter
    here's the writeup with the pictures. http://automotive-diy.com/AUDI/A4/A4_8/A4_8.html
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    Re: Fuel filter
    there is no regulator in the fuel filter, there is a check valve, but our cars use a returnless fuel system, ME varies the voltage to the fuel pump to control the fuel pressure.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Re: Fuel filter
    Actually there is a crude regulator of sorts in the filter. The return line is controlled by a spring loaded valve that opens to help maintain a fairly even pressure on the delivery system.
    Jul 09 2007
    01 A6 4.2 QUATTRO
    Portland, OR
    Re: Fuel filter
    i fail to understand old guy, if the system is not returnless, meaning it returns at the filter how does it differ pressure from idle to WOT, as i understand it is a returnless system, and ME controls the voltage to the pump? is it a damper in the filter, i can understand that.
    Dec 28 2006
    Western Maryland
    Re: Fuel filter
    The returnless system was one of the biggest hurdles that the tuners had to face when it first came out. Typically with a turbo motor the fuel system pressure regulator gets an "adder" from a boost signal line to help maintain a constant fuel pressure delivery. So if you wanted more fuel you didn't have to change the injectors, just turn up th pressure regulator (within reason). with the returnless system the fueling has to be controlled by the injector duty cycle since the pressure differential changes with boost pressure rather than remaining a constant.
