Results 1 to 28 of 28
Thread: Engine Sludging
    Jun 08 2008
    Calgary AB Canada
    Unhappy Engine Sludging
    So ive recently got a CEL for running too lean and idle rpm being too high, alogn with that ive had a loss of power.
    My friend that works at audi told me that its an engine sludge issue and asked me to take my oil cap off while the car was running to see if there was vacuum. sure enough, i couldn't get the thing off!
    He told me that it will by $1000 in part and $1000 in labor to get it fixed!
    I hear this is a common issue with these cars, and has anyone managed to remove all the sludge from wherever the hell it is?
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Re: Engine Sludging
    I dont know what year/mileage your car is, but I think Audi extended the warranty to address to sludge buildup.
    Jun 08 2008
    Calgary AB Canada
    Re: Engine Sludging
    its an 04 with 160000km but dumbass me didnt get any service records with the car, so the warranty wont cover me.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: Engine Sludging
    Quote Originally Posted by onceover View Post
    Is that a reliable test for sludge? I might need to try it.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Re: Engine Sludging
    Try to AutoRx, that seems to work mircales with sludge.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Jun 08 2008
    Calgary AB Canada
    Re: Engine Sludging
    Quote Originally Posted by manhertm View Post
    Hm, just took a look at their site, might have to try it.
    I was also thinking of trying seafoam, but will AutoRx work better?
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Engine Sludging
    Pull of the valve cover and look to see.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 18 2008
    leicester UK
    Re: Engine Sludging
    I suffered the Oil sludge, My oil light came up, then went off for 2 weeks, No loss of power whilst it came up but 2nd time it came up, my engine sounded Loud, tapping.Due to the Starvation of oil circulation and not getting to the top of the engine. Then went bang, blew engine and turbo in one go!!!!
    You need to get it checked ASAP because if it is then the Pick up pipe is blocked due to the sludge then starves the engine because the Pump cant pump the oil it needs round your engine.....then Pop, its gone. Cost me £3200 to get it fixed with Recon ($6000 +) and kicked me right in the nutts!!!!!!!!!!
    Doesnt sound like sludge issue to me though. Get it in for a proper diagnostics mate...
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Re: Engine Sludging
    Quote Originally Posted by dirtybrd View Post
    I with dirytbrd, take off your valve cover and check it for yourself. Is not a hard job to do. I would still do AutoRX anyway though.
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Re: Engine Sludging
    Are you guys really using this? It is not recommended to be used with Synthetic Oil.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Re: Engine Sludging
    Quote Originally Posted by 04QuattroTurbo View Post
    Use reg oil while you do it and switch back to synthetic when the treatment is complete.
    Veteran Member Four Rings jursch2211's Avatar
    Feb 05 2008
    Illinois
    Re: Engine Sludging
    If you read on the AutoRx site, it does state that you can run it with any oil. Putting it in with synthetic just doesn't do as good of a job due to competing chemicals.
    Jun 08 2008
    Calgary AB Canada
    Re: Engine Sludging
    so should i run it with syn or regular?
    for how long?
    can it be bought somewhere locally or do i have to order it?
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Re: Engine Sludging
    for how long?
    It's all there on the website. Not sure if you can get locally.
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Re: Engine Sludging
    eh 1000bucks? Probably try to check with a reputable shop before you dump 1000bucks
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Established Member Two Rings aleccolin's Avatar
    Feb 17 2008
    The 757
    Re: Engine Sludging
    Auto-Rx works, I've used it many times in naturally aspirated and turbocharged cars.
    You have to buy it online, at least I haven't found anywhere else that carries it.
    Use traditional "dino" oil and follow their directions closely. For turbocharged cars don't dog the thing while doing the treatment, which means a couple thousand miles of keeping it out of boost (for the most part) which isn't fun, but you'll love your fuel mileage so long as your car is properly tuned.
    Oh, and for the initial treatment don't bother getting a filter tighter than maybe 15 microns. Use a 10 or 5 micron filter for the "flush" cycles. If you care to, cut the filters open at the end of each stage and keep them for comparison. Yikes, the stuff that comes out of even a well cared-for engine.
    *Note: Don't go TOO cheap on filters, because really cheap ones sometimes pass too high a percentage of 20-25 micron particles, which are still smaller than most of your oil films in the engine, but not if they're heavily varnished surfaces. I usually go standard Purolator, then a PureOne, then back to synth and a Mobil 1.
    Veteran Member Four Rings junkie1.8TQ's Avatar
    Dec 03 2005
    2004 A4 1.8TQ
    Charlotte, NC
    Re: Engine Sludging
    i'm off my treatment of auto rx... like stated above just run dino with your treatment and then switch back after your rinse phase. I got my large Mann filters form germanoilfilters.com or you can get them at ecstuning.com
    I'm running Motul Specific right now and I can definitely feel a difference in the change of oil and i guess the treatment helped also. btw i'm at 55k miles.
    2004 Audi A4 1.8T Quattro 6-speed
    • Bilstein PSS9 • APR Stage 1+ w/ TT225 Injectors • Forge 007
    • JHM SS • Oettinger RZ 19x8.5 • Podi • RS4 Rear Sway
    Apr 08 2008
    Toronto, Canada
    Re: Engine Sludging
    Did you buy it off lease? If so the dealer should have those on record as did mine. I ran into a sludge issue, one turn of the key and it was over. Dealer had previous owners maintenance on record and I had the remaining. Engine and turbo were replaced along with new vac lines.
    2002 Crystal Blue Metallic A4 1.8T Quattro
    2004 Black Volvo S60 2.5T AWD
    Feb 17 2008
    Re: Engine Sludging
    What does taking the oil cap off while the engine is running have to do with sludge?
    Autorx can be used with any group 3 oil including mobil 1 and castrol syntec. I'm 1/2 way through my first autorx cycle.
    02 Audi A4 1.8T Dolphin Grey Pearl 5 speed Retro Solutions HID Podi boost gauge Stern snub
    92 Mustang LX 347 stroker
    Jun 15 2008
    Fairfield, CA
    Re: Engine Sludging
    Quote Originally Posted by junkie1.8TQ View Post
    Sounds like a bout of Chemotherapy or pet dog on with fleas...
    USP Member 110
    Dec 03 2005
    2004 A4 1.8TQ
    Charlotte, NC
    Re: Engine Sludging
    ^ Ha!
    Registered Member Two Rings TripnA4's Avatar
    May 12 2008
    Dallas, TX
    Re: Engine Sludging
    Quote Originally Posted by demea View Post
    Whats the extended warranty on sludge buildup??
    Apr 08 2008
    Toronto, Canada
    Re: Engine Sludging
    Quote Originally Posted by TripnA4 View Post
    I had mine covered. Audi's warranty is extended until 2010 or 2012 BUT you must provide all your oil change receipts. There should be a sticker under the hood or in the glove box stating the warranty.
    Jun 15 2008
    Fairfield, CA
    Re: Engine Sludging
    Quote Originally Posted by lorvar View Post
    Even if you did the change yourself? Just provide the receipt of the purchase of the oil?
    USP Member 110
    Apr 08 2008
    Toronto, Canada
    Re: Engine Sludging
    No, I did the changes at my friends Toyota dealership, bring the oil, filter and out the door for $18, AND I get a receipt. Seriously, it's not worth doing it myself knowing the about the sludge issue.
    Jun 15 2008
    Fairfield, CA
    Re: Engine Sludging
    Maybe, I need to make some "shop" friends...
    USP Member 110
    Jun 08 2008
    Calgary AB Canada
    Re: Engine Sludging
    Alright, im going to order some AutoRx.
    How many bottles should i get for a thorough clean?
    Jun 08 2008
    Calgary AB Canada
    Re: Engine Sludging
    after a bit of searching I found this thread: http://www.audizine.com/forum/showth...=engine+sludge
    It sounds tempting to try the diesel flush... but i dont want to screw anything up.
    Anyone ever hear of trying something like this?
