Results 1 to 28 of 28
    Active Member Three Rings PROXUS's Avatar
    Jul 19 2005
    Chicago
    Arrow Audi Navigation RNS-E plug & play package for A4 / S4 / RS4 - B6 and B7
    For sale: Navigation unit for Audi A4 / S4 / RS4
    for US & Canada.
    Manufactured 2008 - part number 8E0 035 192 P
    DVD maps included in the package
    CLICK HERE to configure your own setup / choose cables / calculate price.
    For full plug & play installation choose:
    1. RNS-E Navigation unit
    2. Symphony II to RNS-E adapter without Bose
    or if you have Bose system: Symphony II to RNS-E adapter with Bose
    3. Radio antenna adapter
    4. GPS antenna or Sharkfin extension cable if you have sharkfin antenna on the roof.
    5. Radio removal tools
    FREE installation within Chicago area
    For sharkfin antenna installation check IMAGES on sharkfin cable product page.
    For Navigation installation, check this Installation Video
    Discount coupon for AZ members:
    During checkout type: MHI8-2SX0-XU9I in Coupons area and you will receive discounted price for full navigation package.
    Jul 19 2005
    Chicago
    Re: Audi Navigation RNS-E plug & play package for A4 / S4 / RS4 - B6 and B7
    to answer some PMs....
    ...yes, it will fit A4 from 2002 and up
    ...yes, you can install it by yourself in 20~40 min. It is more radio unit swap than install.
    ...to check if you have Bose or not, look for BOSE logo on your speakers or check if BOSE logo is displayed when you turn your radio ON.
    ...yes, unit is coded to match your car specs
    ...sharkfin antenna connector is located under ceiling trim (rear window, upper corner passanger side)
    Nov 09 2007
    Australia
    Proxus, do you have a dvd/multimedia kit that allows control through the rns-e?
    if so, how much?
    Thanks.
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    Awesome! How long is the coupon code good for? Where can I get the VAG info needed for the install? And does the radio come with the unlock code?
    2010 BMW 335i Sapphire Black + Black leather interior + Sport + Nav + PDC. Mods - Carbon Fiber wrapped interior - Gloss Black grill - 15% tint - more coming
    2006 A4 2.0T Quartz Grey + Black leather interior + Convenience. Mods - 19" VM RS4 reps - FK Silverline coilovers - APR 93 - Navigation - S4 mirror caps - S-Line E-Codes/Bi-Xenons - XenonMatch Hoen Fogs - RS4 sport pedals - LED License plate lights - black grill - 15% tint all around & More mods coming.
    Sep 18 2007
    Woodbridge
    I have a 2004 S4 with the standard C type nav and phone. My car already has the sharkfin antenna, and i wondering if all the plugs would be located behind my bose deck. I live in toronto, Canada and if u have the map i need. Ill purchase this unit asap. thx
    Jul 19 2005
    Chicago
    Quote Originally Posted by billq View Post
    if so, how much?
    Thanks.
    Multimedia kits are currently out of stock. Sign in for newsletter and you will get information as soon as availability status will change
    Quote Originally Posted by Kid Red View Post
    Units are already coded to match your car specification, so there is no need for VAG. They come of course with unlock CODE. About the install...just look at the installation video in firs post.
    Quote Originally Posted by SROAR View Post
    Probably your car doesn't have quadlock connector behind and you will need adapter. I will need to double-check that, or you can eamil me picture of your conectors and I can tell you for sure. Canadian maps are included.
    Feb 05 2008
    Orlando, FL
    Thanks for the answers. How long is the coupon code good for?
    Jul 19 2005
    Chicago
    this month for sure, maybe I will extend it for another one
    Feb 05 2008
    Orlando, FL
    Sweet, that buys me some time then. Thanks.
    Jul 19 2005
    Chicago
    PM or email me if you will have any questions
    Feb 05 2008
    Orlando, FL
    I emailed you, the coupon code didn't work.
    Feb 05 2008
    Orlando, FL
    Sweet, ordered. Thanks.
    Veteran Member Four Rings seph's Avatar
    Norwalk, CT
    coupon code did not work for me either
    -Ant
    2012 A5 2.0TQ 6MT Ibis white
    Jul 19 2005
    Chicago
    I sent you new one.
    Everyone else, ...be aware that this is one coupon per purchase. If you use it for testing, your coupon will become invalid.
    Established Member Two Rings nferguson's Avatar
    Jun 11 2008
    So, Ca
    do you know when you will be getting more in stock??
    Jul 19 2005
    Chicago
    I still have 3 more and another 10~20 coming within next 2-3 weeks
    Veteran Member Three Rings spidey9999's Avatar
    Oct 19 2006
    Hi. I have '07 A4 with Bose, Bluetooth and factory Sirius receiver (P/N 8E0 035 593 H). Is this Sirius receiver plug and play with the RNS-E unit you are selling?
    Thanks
    Jul 19 2005
    Chicago
    This should be compatible because it is new version.
    If you connect RNS-E you will see Sirius option under BAND menu
    Oct 19 2006
    Quote Originally Posted by PROXUS View Post
    If you connect RNS-E you will see Sirius option under BAN menu
    Norwalk, CT
    I'm having some difficulties with the instrument cluster. The directions say to remove the small plastic trim above the steering wheel and take out the two torx screws which i did....Then it says just pull out the instrument cluster.... yea it doesn't come out. am i missing something? I can't get this thing out for the life of me.
    Ok so i figured it out, apparently it was just very tight i had to remove the fuse panel cover and push the cluster out from the inside... it was still very difficult but i got it out. So far everything is working great.
    Thanks a lot
    -Ant
    Feb 05 2008
    Orlando, FL
    I'll be installing mine tonight and tomorrow to the shark antenna. Hope it goes well.
    My only other questions are will the mode button on the steering wheel now work? Or does that need to be VAG-ed. Also, since I don't have bluetooth, I won't have a mic for the voice commands I guess? So, where/what do I do for bluetooth and a mic? Seems you are out of stock.
    Feb 05 2008
    Orlando, FL
    Are there any text directions for the shark fin installation? Is that blue plug just sitting up there waiting to be plugged into? Do you need to remove the headliner? If so, how?
    Veteran Member Three Rings Gondi Stylez's Avatar
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    Do these units have the new firmware w/o warning screens etc.?
    '02 DG A4 3.0Q 6MT | Member of Club 3.0
    .:. OEM+ : Custom I.C.E : Vogtland GT : Hartmann : SPP : Hawk : Goodridge : JHM : Apikol : 034 .:.
    Sep 08 2005
    B7 A4
    LA
    how much discount is the coupon code?
    Feb 05 2008
    Orlando, FL
    5%
    I got mine hooked up and working. Real cool. Nav tracking isn't exact all the time but then after a while it catches up. Not sure if there's a sure fire way to calibrate. I do miss the volume feedback for the user, I have no idea the volume level. Sound quality also seems improved over the symphony 2.
    Now I just need the bluetooth and backup camera :)
    Senior Member Two Rings Polskidebesciak's Avatar
    Nov 06 2007
    Old Bridge, New Jersey
    what do you mean?
    Feb 05 2008
    Orlando, FL
    Quote Originally Posted by Polskidebesciak View Post
    what do you mean?
    On my symphony, when you turned the volume up, the numbers of the current volume level would increase. Now on the NAV, there is no volume indicator, no numbers, no meter or anything. So the music just gets louder or lower, no visual aid as I am used to. Not a big deal, just wanted to mention that I miss that.
    Oct 22 2006
    B6 3.0 Q
    Calgary, Canada
    If you connect an aftermarket DVD player do you still need the MMI interface to watch DVDs, play CDs, etc?
    Also, with the new BT system could I just BT my iPOD Touch and listen via the speakers? When a call comes in the volume quiets/cuts, etc. etc?
