I have the Bose system on my Avant and although the sub output of the Bose is adequate at higher volume, the bass is barely present at normal (lower) listening level. The bass is turned all the way up on the 2 band EQ, so I presume there's nothing more that could be tweaked internally. I decided to look into an aftermarket sub (8" or 10") installed in the stock location, not losing any trunk real estate and after a visit to a very good shop, it turns out that there isn't enough room behind the panels on either side for a flush sealed enclosure. I've been told by the installer that the only 2 choices I have is to build a free-standing enclosure (approx. 1 cubic foot) and put it behind the rear seats firing backward or relocate the sirius unit (located behind the panel on the drivers side) and fabricate an enclosure that would stick out 4-6 inches. None of these 2 options seem very attractive to me. I've searched a bit on this and haven't found any other solutions for B7.
