Results 1 to 8 of 8
Thread: used EFKs?
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    used EFKs?
    yo i need a EFK stat... no jhm kits or vast (no credit card). any ebay or used ones that you'd recommend?
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    Re: used EFKs?
    just get a generic electric 13 inch fan (or whatever size you want/can fit) and mount it and wire it. saves you around 200 bucks. you can buy generic electric fans even at pep boys/auto zone/ or a performance shop. should run you like 70 bucks.
    might have to spend a bit more time figuring out how to mount it, but saving well over 100 bucks is worth my time.
    Veteran Member Four Rings s vier's Avatar
    Dec 10 2006
    Wisconsin
    Re: used EFKs?
    Quote Originally Posted by XJinCT View Post
    Saves $200? VAST kit is $170. Saves maybe $50.
    2015 Suzuka RS5 Black Optics
    Wings
    Carbs
    Titaniums
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    Re: used EFKs?
    someone care to do the legwork for me? i dont know what sites to go to to buy the EFK, and what is needed after. any writeups?
    people just hook it up to an on off switch? or a thermo switch? both?
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: used EFKs?
    Quote Originally Posted by DxC View Post
    Mine comes on with the AC, and also comes on when engine temps reach 95C - about center of the temp gauge.
    Wiring diagrams: http://jhmotorsports.com/tech/VAST_E...ied_by_JHM.doc
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Jul 07 2007
    Tempe, AZ
    Re: used EFKs?
    so would i jsut need a power cable (from battery) for it, a ground cable, and a remote cable goign to a rocker switch in the cabin? I can wire pretty well. mount it right where that one right below the sway bar is now? or above that?
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Re: used EFKs?
    Quote Originally Posted by jungb5s4 View Post
    Did you read that doc file ?
    The kits also come with a plate that covers the hole that is left once the conventional is removed. Without this cover, the timing belt will be exposed.
    Lots 'o Goodies
    Jul 07 2007
    Tempe, AZ
    Re: used EFKs?
    my gay computer isn't opening it correctly, it's giving me a bunch of fucking weird letters... i'll google it see if i can get a pdf or something
