Results 1 to 10 of 10
Thread: Lug Bolt Sizes
    Established Member Two Rings SouRce4's Avatar
    Dec 02 2006
    Lug Bolt Sizes
    I have new rims and need to purchase some Lock Bolts. What size do i need for an 8.5 in wide rim with a 35mm offset? how is the bolt measured? thread to thread or thread to head?
    '99.5 A4 1.8t FrontTrack 5spd
    ST Chipped K03s :: Custom Catback Exhaust :: Bailey DV :: Custom Intake
    Koni Coilovers :: Strut Bar :: 8000k HID's
    Custom Interior :: Custom Dash and Gauges :: 30% Tints
    Blacked Out 360°
    DÜB Wehrmacht / / / Many Audi's and VDubs
    Registered Member Two Rings manufan's Avatar
    Nov 16 2007
    98 A4 2.8 QM 93 Ducati 900ss
    northern pa
    Re: Lug Bolt Sizes
    The wheel width and offset have zero to do with lug length. If you run spacers, then you need to use longer lug bolts.
    Dec 02 2006
    Re: Lug Bolt Sizes
    so i do not need longer bolts as long as its not spaced?
    Blacked Out 360°
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Re: Lug Bolt Sizes
    depends on the wheel, you'll need to check and see if it uses ball seat or cone seat bolts and you want 6-7 full turns of thread engagement in the hub. Length is measured on the threaded portion only.
    Nov 16 2007
    northern pa
    Re: Lug Bolt Sizes
    You need to know if your new wheels have conical or ball seats. Generally, aftermarket wheels are conical so you can't use stock lug bolts which are ball seat. So, they don't need to be longer, but they need to match the seat in the wheel.
    Veteran Member Three Rings B5Burn's Avatar
    Feb 25 2007
    1998.5 A4 2.0BT
    Winnipeg, Manitoba Canada
    Re: Lug Bolt Sizes
    Quote Originally Posted by Skyler@Achtuning View Post
    Quick Q: "want" 6-7 full turns? or is this mandatory? Neither of my current cars (B5 A4 and 05 VW GLI) get 6-7 turns... and the VW bolts are OEM.
    I need to buy new bolts for my Audi and have always thought they were too short (a little more than 4 turns, 5 max), is there a method for determining the length? I guess using some thin device to measure the depth of the wheel plus hub...
    I would really love to go to a stud kit, which I have an even harder time figuring out sizing of....
    B.
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: Lug Bolt Sizes
    If you're doing some stressful driving, get as many as gets full engagement (6-7) w/o going THROUGH the hub into something (like a rotor) behind it.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Nov 16 2007
    northern pa
    Feb 25 2007
    1998.5 A4 2.0BT
    Re: Lug Bolt Sizes
    Ahh, that clears it up nicely,
    Feb 20 2008
    New Jersey
    Re: Lug Bolt Sizes
    I have a set of tuner lugs with the key for sale. I'm in NJ.
    Let me know if you guys want it.
