Originally Posted by
JJPA4SE
First off, sorry this is not my stomping grounds but I have the B6S4 front brakes on my A4. Also, sorry this is long...
So.. i got new regular slotted rotors from ECS on the front and new Hawk HPS pads on the front... when i first left the garage they seemed a bit spongy (compared to the OEM Pads/Rotors on the car previously). I didnt think much of it thinking that i needed to bed them in. So, i bed them in and after i drive around a little thinking they would be cooled off and they still suck and actually are a bit worse. So i get home and look at the rotors and they seem to be a bit 'glazed over' and the outside edges of the slots are kinda.. gone. \/ see \/
so.. i gave it a few days thinking it would get better and its not (hence this post). Currently they are still really spongy and when i get on the brakes i can hear/feel the slots, i think, cutting into the pads (which is what might be 'filling' the slots).
sorry this is long but i'm in need of help as the $$ i spent is not workin worth a shish..
TIA
(I also did the same combo for the rear stock A4 brakes and i have no such problems)
1. ECS rotors use some of the worst metals to make their rotors. That being said, they don't absorb their share of the heat thereby forcing the pad to take on more heat than it should. You could of very well glazed your pads and there isn't any amount of fluid bleeding that is going to solve your problem.
2. Bleeding you brakes every 15k is recommended. Bleeding between brake changes is not necesary one does not need to do it if they don't allow air into the lines.
3. Would I have bleed my brakes? If I did new pads and new rotors, yes I would have gone the extra distance and bled the brakes.
Solution:
1. Bleed the brakes to eliminate a fluid problem.
2. Take your pads off the car and sand them. You may have overheated your pads during your bedding process causing them to glaze. don't kow for sure but the normal process is, several applications from 30 to 0 before you do the 60 to 20 stops. You're to pull the car over and let it cool to air temperature, a few hours.
3. Scrub your rotors and hit them with some brake cleaner.
If you want a real good way to bleed your brakes, go and get four speedy bleeders. Look for part #12701.
http://www.audizine.com/forum/showth...peedy+bleeders
