Results 1 to 8 of 8
    Registered Member Two Rings Kev3.0's Avatar
    Feb 10 2006
    02 A4 3.0QM, 01 A6 2.8
    NoVA
    Lights are Too Dim!!
    I have a 01 A6 2.8 with the halogens. The lights are very dim at night. I can barely see anything at night. I had Audi look at them and they said they are fine. What do you guys think? I am unsure of how HID kits work and Xenon Housing and Ballasts work. What is the best solution? Also if HID kits is my cheapest solution how do you install them, or do I need to get a shop to install them? Thanks in advanced for your help.
    Senior Member Three Rings PMR2.7t's Avatar
    Mar 26 2008
    2003 A6 2.7T
    Harwood Heights, IL
    Re: Lights are Too Dim!!
    Your best option is to get HID KIT they are easy to install and you could get a PLUG & PLAY kit. Get a 4300K or 6000K kit both kits are bright.
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    How old are your bulbs? If you are unwilling to spring for a full HID kit, get new bulbs.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Veteran Member Three Rings scot_w's Avatar
    Apr 05 2006
    '04 allroad 4.2, '00 A4 1.8T QWSM
    Quote Originally Posted by Kev3.0 View Post
    I agree with PMR2.7t. HIDs should be your first consideration. The next step up would be the Euro projectors with the HIDs (different, more focused beam pattern).
    How do HID ballasts work in general?
    And I will save you some research:
    OEM HID/Xenon upgrade content (long) and research website
    Feb 10 2006
    NoVA
    Where can I get a good HID kit for my car? How much do they run? How do you install the ballast to the existing wiring?
    Feb 10 2006
    NoVA
    bump
    Established Member Two Rings stevea6/z28's Avatar
    Jul 29 2007
    01a62.7t,2z28's,71exercisebike
    conn
    Take Headlights Apart N Take Out The Restricters Did It To My 98 And 01 Huge Difference.
    Veteran Member Four Rings oc-drop's Avatar
    Nov 20 2005
    B7 A4, C5 A6, 79 Camaro
    Newport to Rancho Sta Marg
    we got a local seller that everyone has been using for HIDs
    http://www.vipwholesaleworld.com/forumspecial.html
    ~Rick .. currently driving a B7 3.2 S-Line 6MT Dolphin Grey | DTMish | EuroGEAR CF Hood | H&R | sick halogen Ecodes | AZ Plate frame
    is it 4:20 yet?
